Author Topic: Whatcha'll think  (Read 4974 times)
Whatcha'll think
« on: Thu, 19 May 2016, 08:16:37 »
Which color for m0re Sp33d...??
Re: Whatcha'll think
« Reply #1 on: Thu, 19 May 2016, 08:18:08 »
Red
« Reply #2 on: Thu, 19 May 2016, 08:19:56 »
Red
what about yellow or orange...  I can't decide...
yellow feels like it's faster than red no?
« Reply #3 on: Thu, 19 May 2016, 08:20:56 »
Red
I would personally go with orange.
Orange is laid back just waiting then.... boom....super speed.
« Reply #4 on: Thu, 19 May 2016, 08:24:45 »
I have black, white, grey, red, orange, blue, and green ethernet cables.  Orange is definitely faster.  The grey one is the least reliable since the clips fell off of both ends, so I'd stay away from that.
Offline katushkin
  • Too Keycool for School
  • Just the guy
« Reply #5 on: Thu, 19 May 2016, 08:25:25 »
Red cars ALWAYS go faster.
Offline jaffers
« Reply #6 on: Thu, 19 May 2016, 08:26:54 »
lmfao
Offline dgneo
  • Supervillain
« Reply #7 on: Thu, 19 May 2016, 08:27:39 »
Use the colors to easily identify what cable goes to what :D
Offline appleonama
  • Trollo en USA
« Reply #8 on: Thu, 19 May 2016, 08:30:03 »
What color for m0re Sp33d...??
keep it subtle.
  • Live long and prosper
« Reply #9 on: Thu, 19 May 2016, 08:32:21 »
is the main reason to have colors
orange cables for production-critical servers, yellow cables for all other servers, black/blue/grey for workstations
tp thread is tp thread
Offline dgneo
  • Supervillain
« Reply #10 on: Thu, 19 May 2016, 08:33:32 »
iLO = Grey, DMZ = Red, NFS = Green, iSCSI = Black
:D
Offline nmur
  • ಠ_ಠ
« Reply #11 on: Thu, 19 May 2016, 08:35:10 »
make custom white cables, made to order
sell to Apple users for $39.99
« Reply #12 on: Thu, 19 May 2016, 08:41:12 »
No racing stripes?
« Reply #13 on: Thu, 19 May 2016, 08:43:21 »
:D
Roku = White (cause it's the longest), Roaming cable = Black (second longest), PS3 = Grey (third longest, taped on), PC = Orange (fastest), Media Server = Thin Black (closest in proximity when installing computer), Ethernet cable storage box = all others
« Reply #14 on: Thu, 19 May 2016, 08:44:39 »
What are u guysus Opinion on   3 piece vs 2 piece RJ45 connectors..??
Yes I haz SSTP-cable
Offline mrbishop
  • Evil Genius
    • Bishop Computer Design web
« Reply #15 on: Thu, 19 May 2016, 08:46:23 »
live dangerously = no jack cover.
Projects
« Reply #16 on: Thu, 19 May 2016, 08:47:54 »
Live even more dangerously = no cover to jack
Offline mrbishop
  • Evil Genius
« Reply #17 on: Thu, 19 May 2016, 08:49:35 »
i'm going in with no protection!
137477-0
Projects
Offline algernon
  • A tiny mouse, a hacker.
    • Diaries of a Madman
« Reply #19 on: Thu, 19 May 2016, 08:57:11 »
For maximum speed, go with pitch-black: the color of black holes, that spiral towards each other, and pull everything else in too. Can't be a coincidence! So black attracts things, like data, right? If it pulls data in too, it has got to be the fastest.
And of course, cover it, so high-speed data does not accidentally escape.
Offline dannrawr
« Reply #20 on: Thu, 19 May 2016, 14:22:04 »
blue
WTF any Bruce, Cosmonauts
Offline C5Allroad
  • Formerly HUNTERANGEL121
« Reply #21 on: Thu, 19 May 2016, 14:35:18 »
Red light waves are faster. So that means the red will be the fastest.
Offline chyros
  • a.k.a. Thomas
  • Hello and welcome.
« Reply #22 on: Thu, 19 May 2016, 15:12:06 »
That's not always true, by the way. That said, everyone knows red means speedy ^^ .
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
« Reply #23 on: Thu, 19 May 2016, 16:13:41 »
I would go with orange, even if it does look like an outdoor extension cord. I think orange is best
« Reply #24 on: Thu, 19 May 2016, 16:51:24 »
Go for gold-plated sleeve to get the squarest bits ... and the most winning.
What audiophiles and Donald Trump would choose: Two kinds of idiots is like a double negative: It must be smart.
Offline Leslieann
« Reply #25 on: Thu, 19 May 2016, 17:34:29 »
You don't need Cat 6 or fancy connectors, just use Cat 5e and save yourself some money. Unless you're doing a large building, Cat 5e is perfectly fine for Gbe.
As for covers. Nope, nope, nope. Those f-ing boots harden over time. Many times I have to cut them off just to remove the cable from the router/switch. I've broken a few locking tabs because of those damn things. I would use them on a mission critical system where idiot techs could bump them, but otherwise, nope.
In a home, you should be able to figure out where things go using a common sense approach. Server first, you, spouse, first kid, second kid. Or go by distance. If you have too many for that, you should invest in a patch panel. Not only will it make labeling easier (numbers and charts for the win), but also cleans up the rats nest. The removal of which will also increase speeds.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
Ergo Clears, custom WASD caps
| Das Pro
Costar model with browns
| GH60
« Reply #26 on: Thu, 19 May 2016, 17:39:50 »
I'm already invested in Cat 6 SSTP, got 1000feet..  I just wanted to add some flair to the new cables I'm putting in..
I suppose I could color just as well with a marker..
Offline rurushu
« Reply #27 on: Thu, 19 May 2016, 20:24:29 »
Of course is Red, it has 3x the speed, no need to decide.
Offline NewbieOneKenobi
« Reply #28 on: Fri, 20 May 2016, 11:48:50 »
Get yellow! All or almost all of the other colours can be found ex factory on mass-produced equipment and are so mainstream. Yellow is not. Plus, yellow is optimistic, it will cheer you up.
Besides, yellow emphasizes your nerd status because you don't care to keep things smooth and sleek, just like people do with their modded high-end keyboards. I vote yellow!
