Author Topic: New Cherry SPEED switch with shorter travel  (Read 7626 times)
Offline plainbriny
« on: Fri, 03 June 2016, 05:28:56 »
Cherry has revealed a new switch in COMPUTEX 2016.
https://www.cool3c.com/article/107156
This switch is gray (silver?) and aimed for speed (and named so). The force is similar to red, but the travel reduced from 1.9 mm to 1.2 mm. Seems only available for Corsair now.
Well, actually they announced it back in April. More info from Tom's Hardware:
http://www.tomshardware.com/news/cherry-mx-speed-switches-corsair,31648.html
« Last Edit: Fri, 03 June 2016, 05:33:45 by plainbriny »
Offline zombiegristle
Re: New Cherry SPEED switch with shorter travel
« Reply #1 on: Fri, 03 June 2016, 05:30:40 »
Man, if I were there I'd have a hard time not stuffing my pockets with switches from that awesome display while nobody's looking.
Offline kingslenkds
    • www.hammerclub.org
« Reply #2 on: Fri, 03 June 2016, 09:27:37 »
wow
Often make the chests are wei spark, the world only intensity (life is alive, waiting to die)
Offline merlin64
    • MechMerlin
« Reply #3 on: Fri, 03 June 2016, 14:03:57 »
Isn't that essentially what Razer does?
Offline klennkellon
  • I like bottoming out
« Reply #4 on: Fri, 03 June 2016, 14:29:50 »
Razers switches are modified Kailh Blues that actuate higher up and have less hysteresis but their travel distance is the same.
And ALPS switches already actuate higher up and are usually better than MX anyway  :))
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
« Reply #5 on: Fri, 03 June 2016, 14:33:38 »
The switch is already featured on the Corsair Gaming K70 RGB RAPIDFIRE. The Amazon price atm is $170; that price and non-standard bottom row tho :(
Offline Sneaky Potato
  • Gunslinger
« Reply #6 on: Fri, 03 June 2016, 14:35:16 »
I'm actually interested to feel switches that have shorter travel. Might be interesting.
Offline Tactile
« Reply #7 on: Fri, 03 June 2016, 14:58:02 »
I think they're talking about the actuation point, not the total travel. They wouldn't be reducing the travel of MX switches *from* 1.9mm because the travel of a MX switch is 4mm.
http://cherryswitches.com/us/product/keymodule-mx-series/
REΛLFORCE
Offline Touch_It
« Reply #8 on: Fri, 03 June 2016, 15:01:34 »
This.
Slightly off topic, travel distance of alps is 3.5 mm. (not sure on accuation point).
Topre is introducing a keyboard where you have 3 different settings for actuation point.
On topic:  Wonder how much of a difference this really makes in apn games like SC2.
Offline Tactile
« Reply #9 on: Fri, 03 June 2016, 15:17:58 »
So many of the really good gamers "float" the switches at just the actuation point, I'm not sure they would be impressed. Those really top-end gamers might be more interested in a lower/faster reset than where the actuation point is.
REΛLFORCE
Offline 0100010
  • Not Sure
« Reply #10 on: Fri, 03 June 2016, 15:21:46 »
This.
Say the MX Speed switch total travel is 3.4mm (compared to others, such as MX Red at 4mm).
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
« Reply #11 on: Fri, 03 June 2016, 15:29:38 »
I see this as a gateway switch to Cherry's new (new?) clear switch housing haha. Looks like Gateron made an impression
Online Findecanor
« Reply #12 on: Fri, 03 June 2016, 15:57:48 »
More reading/listening:
Youtube: Linus Tech Tips: BRAND NEW Cherry MX Speed Switches! - Corsair Booth, PAX East 2016 (April 27)
Geekhack: MX Silver (Speed?) Stem Pictures (May 08)
I had collected info in The DT wiki, but not seen anything new to enter since April 28.
Is there really that big a difference between Kailh and Razer blues?
I thought the actuation distance was a property of the Kailh switches ... which Razer chose to blew up as a feature because only to justify the change to another manufacturer.
« Last Edit: Fri, 03 June 2016, 16:06:21 by Findecanor »
« Reply #13 on: Sun, 05 June 2016, 01:18:35 »
Now it's going to be even harder to recommend keyboards to people, with dozens of manufacturers, hundreds of keyboards, and an ever-increasing number of switches!
Offline bazh
« Reply #14 on: Sun, 05 June 2016, 02:27:50 »
But isn't it nowadays Cherry switches line up is still much less than the old days?
And that alone was not couting the world of Alps :))
HHKB Pro2 white
Newbie again
« Reply #15 on: Sun, 05 June 2016, 03:21:48 »
The Marketing guy goes to the engineer, Klaus, I'm running out of stuff to sell to these kids..
Engineer Klaus::   Hang on..  click click, Solidworks,  click click, extrude cut,  Ok here you go.. we shaved off a little on the stem there..
Marketing guy foams at the mouth..
We're gonna make millions..  $$$$$$$$..
« Reply #16 on: Sun, 05 June 2016, 03:26:04 »
Engineer Hanz: But wait Klaus,  how much difference in travel does that influence..??
Engineer Klaus:  Verpiss dich..   I don't know... just put a larger +/- tolerance in the spec sheet so they can't sue us.... Now, go away, I'm busy with the mid-week sausage competition ..
Offline FrostyToast
  • Litshoard
« Reply #17 on: Sun, 05 June 2016, 03:27:48 »
Eventually they'll keep applying this same marketing to switches and we'll end up with Cherry MX butterfly switches.
Quote from: elton5354
« Reply #18 on: Sun, 05 June 2016, 03:32:12 »
not likely, apple already patented everything related to butterflies..
Offline FrostyToast
  • Litshoard
« Reply #19 on: Sun, 05 June 2016, 03:34:50 »
I've got it. They'll just use a projector keyboard but it will come with a plate for mounting Cherry caps that aligns with the projector.
I can see it already.
"Cherry MX Lightning: Type with the speed of light! "
It'll even use an rgb projector to increase gaming performance.
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
« Reply #20 on: Sun, 05 June 2016, 09:21:22 »
You keep mentioning a projector keyboard. I wonder if you're already using.. :blank:
Offline 0100010
  • Not Sure
« Reply #21 on: Sun, 05 June 2016, 09:26:57 »
Thought there already was a gaming targeted optical interrupt switch?
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
« Reply #22 on: Sun, 05 June 2016, 09:45:56 »
Yep but those are switches. I think FrostyToast likes those projector keyboards for some reason /shrug
Offline Wazazaby
« Reply #23 on: Sun, 05 June 2016, 09:59:16 »
Like reds with o rings
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
« Reply #24 on: Sun, 05 June 2016, 10:29:53 »
Good lord, finding o-rings for the speed switches might be a bit of a challenge
Offline Wazazaby
« Reply #25 on: Tue, 07 June 2016, 04:15:23 »
Do you even need o-rings for it ?
Offline ThoughtArtist
« Reply #26 on: Tue, 07 June 2016, 19:04:25 »
Yes. And plastic covering for my bed so I don't wet it at night.
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
« Reply #27 on: Tue, 07 June 2016, 19:09:58 »
So that you can soak your bed frame in urine? Lovely
Offline FrostyToast
  • Litshoard
« Reply #28 on: Tue, 07 June 2016, 21:01:35 »
I made replies mentioning projector keyboards maybe three times.
It's not that often I make comments on them.  :confused:
