Author Topic: Not gonna Lie, Am aroused  (Read 3962 times)
« on: Tue, 13 September 2016, 23:25:25 »
Look at this cable.....
41 strands, 34awg
18awg conductor total
Tinned Copper
Corrosion Resistant
PVC Insulator
41 Shielding strands
Cotton paper flexsheet
TPU flexible outer jacket
148281-0
Re: Not gonna Lie, Am aroused
« Reply #1 on: Tue, 13 September 2016, 23:26:46 »
damn i'm erect
****s wrong with u tp4
« Last Edit: Tue, 13 September 2016, 23:37:57 by Sifo »
Offline chyros
  • a.k.a. Thomas
  • Hello and welcome.
« Reply #2 on: Wed, 14 September 2016, 05:19:26 »
wat
« Reply #3 on: Wed, 14 September 2016, 05:20:06 »
Put it in ur bum
Offline dgneo
  • Supervillain
« Reply #4 on: Wed, 14 September 2016, 05:23:21 »
Offline katushkin
  • Too Keycool for School
  • Just the guy
« Reply #5 on: Wed, 14 September 2016, 05:29:35 »
But what is it for...?
« Reply #6 on: Wed, 14 September 2016, 05:59:53 »
tp4 is an AI, it's probably part of his infrastructure.
« Reply #7 on: Wed, 14 September 2016, 07:16:57 »
That is an impressive piece of gear. Is it for TV cable?
- D Trump 2026-10-24
Offline Spopepro
« Reply #8 on: Wed, 14 September 2016, 08:14:46 »
Eh, you get going for a pvc dielectric layer? You're a cheap date. At least hold out for ptfe.
Offline jaffers
« Reply #9 on: Wed, 14 September 2016, 08:46:08 »
Looks beaut
« Reply #10 on: Wed, 14 September 2016, 08:51:45 »
I think the way it's designed,  it's suppose to have some rigidity for the first layer to keep the wire bundle together more tightly. ptfe or even the tpu of the outer layer may be too soft and the inner conductor strands need a bit more support.
PTFE also has poor cold temperature performance..  I need a wider hot and cold range which works with the TPU.
Offline Moistgun
  • Slippery When Wet
« Reply #11 on: Wed, 14 September 2016, 08:55:01 »
DAMNIT TP WHATS IT FOR
Offline Spopepro
« Reply #13 on: Wed, 14 September 2016, 09:04:49 »
You need something outside the ranges of mil spec M17/75-rg365? Coax, tpa jacket, LDPE dielectric, silver plated copper strands, operating range -55c to 85c. 5000v operating max. 30.8pF/ft which is great for a coax cable.
But I understand horses for courses and match the application and all that.
Offline Bromono
  • Wanabe Cicerone
  • HHKB > Your Opinion
« Reply #14 on: Wed, 14 September 2016, 09:08:40 »
I always fall for the click bait.
« Reply #15 on: Wed, 14 September 2016, 09:26:00 »
That material at that diameter/thickness can do --those-- things.  but it's not certain it will do that when scaled down.
Offline Spopepro
« Reply #16 on: Wed, 14 September 2016, 09:58:27 »
Ah, that's the part I was missing. It's 4mm nominal. In that case, carry on...
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
« Reply #17 on: Wed, 14 September 2016, 10:39:30 »
Sir, I think I found your problem--there is copper in your fiber optic cables
Offline chyros
  • a.k.a. Thomas
« Reply #18 on: Wed, 14 September 2016, 15:01:05 »
Put it in ur bum
Increased uploading to bum, I'm sure tp will be thrilled :p .
« Reply #20 on: Wed, 14 September 2016, 18:43:23 »
Bums are 100% for downloading. No exceptions.
Offline mike52787
  • Alps Aficionado
« Reply #21 on: Wed, 14 September 2016, 19:11:28 »
Have to agree with you there
