Author Topic: Hair Dryer Broke  (Read 8113 times)
Hair Dryer Broke
« on: Sun, 11 June 2017, 21:32:23 »
Dried my hair with my hitachi leaf blower.
Works way faster than hair dryer..
Also leaves your hair smelling Manly.. // Fresh Gasoline //
Key-Note,   Don't breath the fumes ...  tape down the trigger, and stand in front of it..
WEAR safety Goggles.
Offline Gajible
Re: Hair Dryer Broke
« Reply #1 on: Sun, 11 June 2017, 21:55:10 »
Looks like you solved the tp4issue
Offline user 18
« Reply #2 on: Sun, 11 June 2017, 22:40:00 »
But the real question is how is the quality of the dry compared to the hair dryer? Does it produce a gently windswept look, or more along the lines of 'drove to work with my head out the window'?
Avatar by ashdenej
Offline mrduul
« Reply #3 on: Sun, 11 June 2017, 23:13:05 »
Always use the power of the sun and wind.
Offline f32h80fsd08h34r5
« Reply #4 on: Mon, 12 June 2017, 00:29:30 »
I might have to give this a try, I get ready for things way too late, and my hairdryer doesn't dry my hair fast enough..   :thumb: thanks!
Offline chyros
  • a.k.a. Thomas
  • Hello and welcome.
« Reply #5 on: Mon, 12 June 2017, 02:24:19 »
What man uses a hair dryer? Oo
Hair Dryer Broke
« Reply #6 on: Mon, 12 June 2017, 02:35:37 »
Didn't expect you to have that much hair. You always say you're old, what are you, a hippie?
Offline chyros
  • a.k.a. Thomas
« Reply #7 on: Mon, 12 June 2017, 05:53:53 »
I had hair reaching to well below my shoulder blades, never needed a hair dryer.
« Reply #8 on: Mon, 12 June 2017, 06:28:02 »
I've heard the quicker your hair is dry, the less bacterial growth .
« Reply #9 on: Mon, 12 June 2017, 06:29:28 »
wear goggles
don't stand too close, wind way too strong.
and also, be careful not to have objects being blown into you like, say a box of nails from the garage, or remove the concentrator tip if that falls off sometimes... hahahahahaha
« Reply #10 on: Mon, 12 June 2017, 07:00:48 »
A man with long flowing hair!
Offline chyros
  • a.k.a. Thomas
« Reply #11 on: Mon, 12 June 2017, 07:01:33 »
Or just, you know, wash it :p .
« Reply #12 on: Mon, 12 June 2017, 07:02:58 »
wear goggles
Alright, thanks! I wouldn't have guessed the goggles part..
Offline SBJ
  • Tactile pls
« Reply #13 on: Mon, 12 June 2017, 08:05:56 »
Getting more and more curious as to what you look like these days tp.
Such an enigma.
« Reply #14 on: Mon, 12 June 2017, 08:54:45 »
Such an enigma.
170682-0
Offline chyros
  • a.k.a. Thomas
« Reply #15 on: Mon, 12 June 2017, 08:54:57 »
Such an enigma.
I always imagine people who never show their picture to be hideous, grotesque monsters :p .
« Reply #16 on: Mon, 12 June 2017, 09:14:50 »
Such an enigma.
Offline SBJ
  • Tactile pls
« Reply #17 on: Mon, 12 June 2017, 09:25:23 »
Such an enigma.
I'm sure it's not all that bad tp. I'm ugly too!
Offline Leslieann
« Reply #18 on: Mon, 12 June 2017, 17:41:55 »
If you wash it every day or so, there won't be enough bacterial growth to be concerned with and any that can manage to grow in that time will be there regardless of how you dry it.
However, excess heat, is TERRIBLE for hair. Women get away with it somewhat because their hair grows slightly faster, but also they spend more time and effort keeping it in good shape. That said, women with really long hair, do not use heat or use very little heat because once damaged, it stays that way. Also, many women's hair is actually not in that great of shape, they just use conditioners with lots of silicone to hide it*.
Personally, I get as much out as I can while still in the shower before drying off, then I use a towel or an old t-shirt and wrap my head in it to absorb excess water. After an hour or so, it's merely damp.
*Not only does it hide the damage from others, but also from you, causes buildup, and in some cases be hard on your houses plumbing.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
Ergo Clears, custom WASD caps
| Das Pro
Costar model with browns
| GH60
« Reply #19 on: Tue, 13 June 2017, 20:12:25 »
How do I know if the product uses silicone..  does it just say silicone  or is it another name.
Offline rarar
  • moist booty seepage
« Reply #20 on: Tue, 13 June 2017, 21:03:26 »
leaf blowers are a bit much for me, I don't want my hair flying OFF!
Ỏ̷͖͈̞̩͎̻̫̫̜͉̠̫͕̭̭̫̫̹̗̹͈̼̠̖͍͚̥͈̮̼͕̠̤̯̻̥̬̗̼̳̤̳̬̪̹͚̞̼̠͕̼̠̦͚̫͔̯̹͉͉̘͎͕̼̣̝͙̱̟̹̩̟̳̦̭͉̮̖̭̣̣̞̙̗̜̺̭̻̥͚͙̝̦̲̱͉͖͉̰̦͎̫̣̼͎͍̠̮͓̹̹͉̤̰̗̙͕͇͔̱͕̭͈̳̗̭͔̘̖̺̮̜̠͖̘͓̳͕̟̠̱̫̤͓͔̘̰̲͙͍͇̙͎̣̼̗̖͙̯͉̠̟͈͍͕̪͓̝̩̦̖̹̼̠̘̮͚̟͉̺̜͍͓̯̳̱̻͕̣̳͉̻̭̭̱͍̪̩̭̺͕̺̼̥̪͖̦̟͎̻̰_Ỏ̷͖͈̞̩͎̻̫̫̜͉̠̫͕̭̭̫̫̹̗̹͈̼̠̖͍͚̥͈̮̼͕̠̤̯̻̥̬̗̼̳̤̳̬̪̹͚̞̼̠͕̼̠̦͚̫͔̯̹͉͉̘͎͕̼̣̝͙̱̟̹̩̟̳̦̭͉̮̖̭̣̣̞̙̗̜̺̭̻̥͚͙̝̦̲̱͉͖͉̰̦͎̫̣̼͎͍̠̮͓̹̹͉̤̰̗̙͕͇͔̱͕̭͈̳̗̭͔̘̖̺̮̜̠͖̘͓̳͕̟̠̱̫̤͓͔̘̰̲͙͍͇̙͎̣̼̗̖͙̯͉̠̟͈͍͕̪͓̝̩̦̖̹̼̠̘̮͚̟͉̺̜͍͓̯̳̱̻͕̣̳͉̻̭̭̱͍̪̩̭̺͕̺̼̥̪͖̦̟͎̻̰ ด้้้้้็็็็็้้้้้็็็็็้้้้้้้้็็็็็้้้้้็็็็็้้้้้้้้็็็็็้้้้้็็็็็้้้้้้้้็็็็็้้้้้็็็็็_ด้้้้้็็็็็้้้้้็็็็็้้้้้้้้็็็็็้้้้้็็็็็้้้้้้้้็็็็็้้้้้็็็็็้้้้้้้้็็็็็้้้้้็็็็็
Offline Leslieann
« Reply #21 on: Wed, 14 June 2017, 04:23:05 »
Any ingredient that ends in "cone" is a silicone.
Dimethicone for example.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
| Das Pro
| GH60
« Reply #22 on: Thu, 15 June 2017, 19:09:59 »
Quality gear like my grandmother's hair dryer won't give out on you after a few decades of use.
- Franklin Roosevelt 1933
« Reply #23 on: Thu, 15 June 2017, 19:13:28 »
I think in this specific case,  it's probably because that hair dryer is only 215 watts..
Offline Leslieann
« Reply #24 on: Fri, 16 June 2017, 00:22:46 »
More likely to electrocute you than dry your hair.  :))
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
| Das Pro
| GH60
Offline ander
  • I type, therefore I am
« Reply #25 on: Fri, 07 July 2017, 17:27:30 »
I just stick my wet head out of the car window and let the breeze dry it. If you do this, it's also important to let your tongue hang out of your mouth like a dog.
