Author Topic: Soup Heat  (Read 5488 times)
Soup Heat
« on: Thu, 31 January 2019, 09:36:36 »
So, you make the soup, and it's done.
Can't eat it, because it's too hot..
We wait for it to reach the operational temperature.
Procedure start.   Yet, Half way into the bowl,  the soup Cools BELOW optimal temp.
What an impossible situation this morning has been.
211841-0
Offline joey
Re: Soup Heat
« Reply #1 on: Thu, 31 January 2019, 09:48:45 »
Would 2 bowls help? Or make it worse?
Re: Soup Heat
« Reply #2 on: Thu, 31 January 2019, 09:56:38 »
Tp4 current solution:
Place soup into warm water tub while in operation to reduce DTemp/DT
Offline Lanrefni
Re: Soup Heat
« Reply #3 on: Thu, 31 January 2019, 11:05:34 »
The solution to ultra hot soup is to make garlic toast to dip into it while waiting for it to cool a little. :thumb:
Re: Soup Heat
« Reply #4 on: Thu, 31 January 2019, 11:44:20 »
But this does not compensate for the Mid-Soup 2kewl dilemma..
Re: Soup Heat
« Reply #5 on: Thu, 31 January 2019, 11:50:14 »
Microwave halfway through, or else only ladle out half a bowl at a time and go back for 2nds and 3rds.
- D Trump 2026-10-24
Offline derznation
Re: Soup Heat
« Reply #6 on: Thu, 31 January 2019, 12:05:22 »
Reheat in pan on stove, take smol bowl and leave the rest on simmer if you want more
Offline JP
Re: Soup Heat
« Reply #7 on: Thu, 31 January 2019, 14:20:35 »
A larger bowl of soup? That or invent something new and take soup to the next level.
About Me | The Collection
Re: Soup Heat
« Reply #8 on: Thu, 31 January 2019, 17:26:18 »
Are you heating it in the microwave, because that only happens if you heat it in a microwave.
Very easy solution: heat it on the stove-top, stirring occasionally. Not only does this allow even and controlled temperatures, but gives you a chance to enhance the dish with spices and other ingredients. Remember, you aren't cooking the soup. It is already cooked. You are only heating it up, there's no reason to bring it anywhere near a boil for that.
« Last Edit: Thu, 31 January 2019, 18:40:06 by noisyturtle »
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
Re: Soup Heat
« Reply #9 on: Thu, 31 January 2019, 18:22:45 »
Moar meat
Re: Soup Heat
« Reply #10 on: Thu, 31 January 2019, 18:49:25 »
Or you could serve the soup cold and eat it with a thermal spoon. Have a thermal adjustment setting that heats the spoon to your desired temp(so obviously you would need to preheat the spoon before eating,) maybe a silicon coating to keep it from burning your mouth. When the spoon detects the temperature change of having the cooler liquid it will adjust allowing the shallow pool to be perfectly heated in seconds. Realistically it would only take about 5-7 seconds to heat each tablespoon which is already about the same amount of time it takes to lift it to your mouth and blow a couple times.
Re: Soup Heat
« Reply #11 on: Thu, 31 January 2019, 19:40:06 »
Eat soup faster.
I've been eating tuna in miso soup lately.
Offline Photoelectric
Re: Soup Heat
« Reply #12 on: Thu, 31 January 2019, 19:42:06 »
Put soup in a thermos tumbler mug.  Eat out of that.
Re: Soup Heat
« Reply #13 on: Thu, 31 January 2019, 19:53:25 »
For tomato soup, and smooth soups this would work.
But what bout peeps prefer dat Chunky..
Offline fanpeople
Re: Soup Heat
« Reply #14 on: Thu, 31 January 2019, 20:12:30 »
No one eats tomato soup anymore.
If anyone posts saying they eat tomato soup.... 10000 FUs to you.
Offline JP
Re: Soup Heat
« Reply #15 on: Thu, 31 January 2019, 20:38:08 »
Offline Sent
  • Simplistic Serenity
  • ¯\_(ツ)_/¯
Re: Soup Heat
« Reply #16 on: Thu, 31 January 2019, 20:42:43 »
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
Re: Soup Heat
« Reply #17 on: Thu, 31 January 2019, 20:58:36 »
What about a bowl of marinara sauce? ?/10
Offline derznation
Re: Soup Heat
« Reply #18 on: Thu, 31 January 2019, 21:03:25 »
You're so right man
#TeamTomatoBisque
Re: Soup Heat
« Reply #19 on: Thu, 31 January 2019, 21:20:48 »
I have an eco-friendly and economic solution that not only will heat your soup to the perfect temperature every time, but also cost nothing in energy resources.
Simply fill a prophylactic with your favorite type of soup or stew, freeze it until preferably slushy and not completely frozen, insert as a suppository, then wait for your meal to heat to your exact body temperature. Remove your meal, cut open the hermetically sealed container, serve and enjoy!
Understandably this technique is not for everyone, and some initial discomfort may be apparent. But for anyone who is a true connoisseur and eco-pioneer will clearly see the benefits of in vivo sous vide.
I'll take my Nobel Prize whenever you're ready Nobel Committee.
Offline fanpeople
Re: Soup Heat
« Reply #20 on: Thu, 31 January 2019, 21:29:27 »
This is allowed. feel free to eat a bowl of marinara sauce without any internet backlash.
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
Re: Soup Heat
« Reply #21 on: Thu, 31 January 2019, 21:35:57 »
Re: Soup Heat
« Reply #22 on: Thu, 31 January 2019, 21:48:58 »
Where does this anti-tomato sentiment come from..  is this a chan thing.
Offline fanpeople
Re: Soup Heat
« Reply #23 on: Thu, 31 January 2019, 23:27:43 »
NOBODY LIKES BLENDED TOMATOS SUPER HEATED AND GARNISHED WITH THE DEVILS HERB
Re: Soup Heat
« Reply #24 on: Thu, 31 January 2019, 23:30:10 »
Don't put the top on.  Those cups keep my tea warm pretty well even without a top.
Offline naasfu
  • The Curator
  • CURSE YOU HE-MAN
Re: Soup Heat
« Reply #25 on: Thu, 31 January 2019, 23:35:42 »
i remember tomato soup with saltine crackers was pretty damned good.
Offline fanpeople
Re: Soup Heat
« Reply #26 on: Thu, 31 January 2019, 23:42:58 »
Offline naasfu
  • The Curator
  • CURSE YOU HE-MAN
Re: Soup Heat
« Reply #27 on: Thu, 31 January 2019, 23:50:51 »
Offline fanpeople
Re: Soup Heat
« Reply #28 on: Thu, 31 January 2019, 23:58:23 »
Offline JP
Re: Soup Heat
« Reply #29 on: Fri, 01 February 2019, 08:14:27 »
I'm pretty sure this is already how they smuggle soups across the border and into prisons.
Offline Sintpinty
  • Carbon Based Life Form
    • My Roblox Profile
Re: Soup Heat
« Reply #31 on: Sun, 17 February 2019, 20:12:55 »
Soup time
Just my thoughts
Offline absyrd
  • CPT HYPE PADAWAN
Re: Soup Heat
« Reply #32 on: Wed, 20 February 2019, 05:53:51 »
I like my soup like I like my coffee; it is either burning my tongue or it is garbage.
Offline chyros
  • a.k.a. Thomas
  • Hello and welcome.
Re: Soup Heat
« Reply #33 on: Wed, 20 February 2019, 07:13:45 »
Eat from the sides, not the middle. Maximises heat loss for eatable soup, yet maximises heat retention for soup you eat later.
Alos, depend on topical cooling, not general heat loss.
