Author Topic: Gaming PC Parts discussion thread.  (Read 409043 times)
Re: Gaming PC Parts discussion thread.
« Reply #1000 on: Thu, 19 March 2026, 16:34:36 »
how BAD youtube bitrate is,
They have to accommodate the 20-year-old laptop on a farm with a dial-up connection ....
"A whole civilization will die tonight."
- D Trump 2026-04-07
What is wrong with this picture?
« Reply #1001 on: Thu, 19 March 2026, 18:13:13 »
20 year old laptops should be able to decode 3-7MB/s video streams at 1080p.
Dial-up DSL can pipe it, Dial-up 56k, no.
« Reply #1003 on: Fri, 20 March 2026, 15:02:47 »
I found out a couple of months ago that DDR5 RAM price was through the roof, but has NAND PCIe skyrocketed now, too?
« Reply #1004 on: Fri, 20 March 2026, 15:25:59 »
Yes, but most people don't need much nand.
Tp4 stocked up on the wd sn850x 4TB @ $221 a piece.
« Reply #1006 on: Sun, 22 March 2026, 12:38:51 »
Wow 4k 240hz is 6.8 GigaBYTE / second.
« Reply #1007 on: Mon, 23 March 2026, 12:35:37 »
Cleaned up 8bitdoo contro.
Feels gud, lubricated spring and loop. Krytox triggr. Made plastic washers to tighten tolerance out of packaging material.
« Reply #1008 on: Thu, 26 March 2026, 08:57:08 »
OMGOMGOMG
Hisense u8 2023 100"inch model for $1500
It does 1500nits, 144hz.  OMGOMG.
MUST RESISTTTT...
« Reply #1009 on: Thu, 26 March 2026, 09:26:27 »
WTH, 3770k are $50-60 now?
4790k used to be $40.
« Reply #1010 on: Thu, 26 March 2026, 10:33:02 »
Hrrrm... $1500... ghhaaaa.  Does Tp4 really need this. hrrrrm.....
It's 144 hz, it's bright, it's got zones, it's 100 inches. sssssss....
« Reply #1011 on: Thu, 26 March 2026, 13:26:31 »
AMD 9950x3d2
2x 8 Zen5 Core + 2x 3D vcache CCDs.
Now, 200 watt TDP.
A SINGLE 9700x for example can pump 175watt peak with PBO MAXed.
So, Really, if we wanted a MAXED out chip, we need 350 watt.
Which they probably won't allow since 230watt is pretty much the max any one gets on the 9950x.
Limitation is probably due to dissipation limit of the size of the die.
BUT what they can actually do is Reduce the thickness of the IHS or sell it delided to enthusiasts in a max 350watt edition.
You'd probably need a 30mm 3x140 AIOwater to cool it, BUH why not, it's enthusiast.
« Reply #1012 on: Fri, 27 March 2026, 16:37:05 »
U know, tried getting through Death stranding many times, just wasn't having fun.
« Reply #1013 on: Sat, 28 March 2026, 12:21:38 »
Really want to get the keychron m5 vertical gaming mouse.
It's got paw3950 sensor + realtek 8762g MCU,  should be around 150 hours
So, it's a fairly power efficient MCU, but not as gud' as if it had the latest nordic nrf54L, 750 hrs.
But 98grams.
Coming from 60g mices, taping 6 quarters to it, it does feel quite heavy, for direction changes. There's really alot of momentum in +40g.
« Reply #1014 on: Mon, 30 March 2026, 08:46:21 »
Sigh. That $1500 100 inch U8K haunts Tp4. Electronics addiction.
"Think of the climate Tp4, respect the earth"
« Reply #1015 on: Mon, 30 March 2026, 09:53:55 »
How is it that DVD drives are still best selling pc accessories?
Who's still buying these, to do what with?
« Reply #1016 on: Mon, 30 March 2026, 12:34:53 »
Driving for 1 hr is 11kg of co2 emission (includes production)
Gaming at 1000watt PC + AC,  is 1 kg
« Reply #1017 on: Tue, 31 March 2026, 15:25:55 »
OMG,,, Budget Work laptops have gotten Soooooo Gimpped.
They don't even solder to a flat heatspreader-plate now, it's just Straight up the pipe,  Not milled, nothing, just a rough, uneven surface.
Truly disgusting. You can barely call it flat. The photo is of the bottom part, that touches the cores.
When did they start doing this?? This is from a dell pro14 14250. Cheap laptop, but still, this is yikes.
In real world, if you drop this laptop hard enough, you can crush the pipe such that the fluid doesn't even flow properly.
316482-0
« Reply #1018 on: Wed, 01 April 2026, 19:50:21 »
Finally downloaded Pragmata demo everyone's raving about.
It's got good GFX for sure, hair physics++, HDR poor- not so well done, At the moment only the SDR looks put together.
Figured it out, Got to set the HDR config in the menu so it doesn't clip.
Gameplay,  well...  it's Ok, it's more/less a slower paced flat room encounter action game like DevilMayCry.
The RayTracing, welllll, yea it's got nice looking reflections.
GPU requirement, sigh.. Unfortunately Tpoor4 only haz 7900xtx, can only do 70-90fps at 4K, that's playable, but must use FSR to hit 120ish.
At least the FSR4 int8 optiscaler works, so not stuck with fsr3.1
« Reply #1019 on: Wed, 01 April 2026, 21:31:53 »
Game streaming service.
People don't understand what they're giving up.
BITRATE.  Max you can theoretically get from a service that Needs to be profitable is maybe 200mbit/s which is 25MB/s
Most services don't even offer this much, you'd be lucky to get 40-100mbit/s, 5-12MB/s.
Whereas,  4K 144hz 10bit, Native output on your pc is at 39.19Gigabit is 4898.75MB/s
That's not remotely the same. the Fidelity loss is ENORMOUS.
« Reply #1020 on: Wed, 01 April 2026, 23:53:00 »
Hahahahahaha.  Saw an online comment on Pragmata just now,  "This, games like this is why 1r4nt wants to destroy america".
Kind of headscratch, it's only weird because it's japanese, and you know the japanese, hahahahah
« Reply #1021 on: Fri, 03 April 2026, 10:49:48 »
Wifi 7 routers,
NE1 upgraded? useful for sumtn'?
« Reply #1022 on: Sat, 04 April 2026, 09:57:18 »
So, Tp4 be like, watchn' anti-w4  ;r,   viz,  while playing murdar simulations (Halo Infinite) on the PC.
Honestly, Culture has to change, this is the problem.  You have this entire CULTURE, Driven by Imperialist Economics,  perpetuating MURDER.
Offline phinix
« Reply #1023 on: Tue, 07 April 2026, 04:02:22 »
Wifi 7 routers,
I think I'm still on 5, even though my mobo gives me 6, I dont even know :)
12100 | 9070XT | 2TB SSD | ROG STRIX B760-I ITX | 32GB RAM | SFX 850W | NR200p | Ruark Audio MR1 Mark II | LG OLED 42C4
Realforce 87u55 | CM QuickFire Rapid MX Blacks | Filco TKL 85g Gateron Oil Kings | Tiger Lite 85g Oil Kings | Logitech Pro Superlight
GSA: Retro High-light  HSA: Hyperfuse  XDA: Canvas  PBS: MV Classic
« Reply #1024 on: Tue, 07 April 2026, 18:05:29 »
Kind of weird, but they don't have a monitor with 1080p 885hz
The new display port should support this no problem.
With DSC, they can even do 4K @ 640hz..  or 1080p @ 1,352hz 10bit, 1,463hz 8bit.
Offline phinix
« Reply #1025 on: Wed, 08 April 2026, 03:47:19 »
Am I weird that I dont pursue Hz in monitors or fps in games?
As long as I have 45-60fps, I'm happy to play a game. My OLED screen is 144Hz, which is easily achieved when playing 20+ years old games (Like Project IGI recently :)), but in modern high-end AAA games I get around 50-60fps, which is fine with me. I only achieved this kind of fps level when I upgraded to 9070XT, before fps in games was lower, like 30-40fps, which was still ok to play.
« Reply #1026 on: Wed, 08 April 2026, 12:30:51 »
Everything is playable at 50-60.
But it is often the case that a few ticks lower + FSR can get you 100+
And now with the large VRR range on oleds, it's a much better experience if you tune it for 100.
Lower shadow 1-2 clicks, lower ambient occlusion 1-2 clicks, disable post processing, use FSR Balanced.
FSR is honestly really good now, because it basically gives you anti-aliasing, whereas most engines don't support good old MSAA anymore due to deferred lighting.  Shader AA is wasteful, when you can just use FSR and get AA + Upscaling all in one step.
Optiscaler Client is the key at the moment, because it can inject FSR 4.0 into most old FSR or DLSS implemented games that aren't FSR4.0 out of the box..
Optiscaler can also injects Frame Gen which is very nice because for the games that Really just won't budge from 70FPS like Clair Obscur, you can get to the 120+ smooth range with Frame Gen.
« Reply #1027 on: Wed, 08 April 2026, 18:43:20 »
Got to 99,999 lines in tetris dx gameboycolor,
So, what happens after is, it just goes 99,999, back to 00001, you can't get more than 99999 lines.
But it allows for up max score of 9,999,999 points.
Weird programming choice.
« Reply #1028 on: Thu, 09 April 2026, 22:19:40 »
Tp4 sitn' here playing Exp33, while middle east children die for western greed.
The inaction is immoral.
« Reply #1029 on: Fri, 10 April 2026, 10:39:06 »
Wth is China doing, do you realize they're destroying the TV market?
4K 85 Inch TV for $680
« Reply #1030 on: Fri, 10 April 2026, 17:09:13 »
In Tp4's humble opinion.
Warcraft III reforged, iz no gud', the extra detail just look messy, and they lacked the artistic vision of the origin.
It's not so much the extra detail being "Bad" on their own terms,
What happens when you make the model more detailed,  when they get shrunk, the units just look messy, and it's hard to tell units apart because of that mess, as the eye has to parse what appears to be a grainy mess.
It was much easier to tell the units apart in the exaggerated "chubby" graphics.
316637-0
« Reply #1031 on: Tue, 14 April 2026, 01:57:11 »
I feel like Jensen is smoking crack pushing this AI filter bull**** no one wants. They don't even need to build new architecture or die set.
All they need to do is release the previous gens GPU with 3x the VRAM and sell it for less. DONE.
****ing dribbling idiots running that company. Who tf do you know running an 8K gaming setup? Oh, no one? Me either! They are pushing the future WAY too fast.
Everyone is struggling just to afford the bare bones to run GTA6
Offline TheSoulhunter
  • ~ GHOST ~
« Reply #1032 on: Tue, 14 April 2026, 16:29:39 »
8bitdoo ....Made plastic washers to tighten tolerance out of packaging material.
Which one are you using? SN30 here. Mind to give a short tutorial on the washer modification?
316704-0
« Last Edit: Tue, 14 April 2026, 16:31:50 by TheSoulhunter »
« Reply #1033 on: Fri, 17 April 2026, 15:21:46 »
Tp4 has the 8bitdo 2C wireless wukong, the analog trigger rides on a metal post. There's a bit too much play left and right after using it for a while, so you go in, poke out the post, lubricate, and add a home made washer.
« Reply #1034 on: Fri, 17 April 2026, 15:23:34 »
Dat new Neogeo coming out.
Hrrrrm... IDK... seems kinda asking too much for games, unless those games come on original chips as well?  That would be the only reasonable way to justify $50-80 game carts for such antiquated games by "modern standards."
« Reply #1035 on: Fri, 17 April 2026, 19:25:34 »
nip
« Reply #1036 on: Sat, 18 April 2026, 17:23:32 »
Woah, they implemented the CRT Beam simulator in Retroarch, amazing motion clarity booost.
https://blurbusters.com/crt-simulation-in-a-gpu-shader-looks-better-than-bfi/
So basically how this works is,  It divides a single frame into chunks.  If you have a 120 hz monitor, it breaks the frame into 2 chunks via a shader,  the shader also accounts for inverse colors etc,  So it works like a scrolling shutter, but with compensation for scroll speed.
Anyway, it works fantastic for both LCD and OLED, more HZ the better. It's like BFI, but more dynamic and no perceptible flicker.
« Reply #1037 on: Sat, 18 April 2026, 19:05:34 »
U know whaz crazy, If you play the PC release of 3rd strike, it looks like garbage.
If you play it emulated + filter + CRT beam emulator.  It looks amaaaazing.
« Reply #1038 on: Sun, 19 April 2026, 15:22:05 »
Beyond All Reason. You feel it, suprem Commander.
« Reply #1039 on: Mon, 20 April 2026, 09:15:51 »
Might get new monitor. Hrrrm.. Pretty gud' deals going round.
Hrrrrrmrmrmrmmrmrmr...
PC parts revenue absolutely TANKING due to the ram/storage bubble,  CPU sales from major retailer down 70%,  Microcenter in shamblez. :'(
If you sell 70% fewer CPU, that's basically 50-70% fewer everything else that goes in the box.
Noticed something odd, we know that Drug Dealers often look down upon their client, those disgusting heroin addicts, etc.
Turns out, PC parts sellers look down on Gamers, spoke to numerous big retailer reps in Asia, they refer to their clients as (transliterated), "gross game players," (meaning), gamers = losers.
Guess there's good reasons Apple doesn't want any association with gamers.
« Reply #1040 on: Mon, 20 April 2026, 10:25:30 »
Just got home,  Dell 4K 32" QD oled, 120hz VRR, USB.C 1.4 + HDMI 2.1
$349.97 Costkooo deal.
Yaaaaaaaaahhhhh.... /Happy runs in circle.
Perfect Budget Monitor of the Year.  Not alot of people know about this model, it's actually pretty gud'.  Still alot of stock at Costkoo, Tp4's store has 10+ still.
Better go get one before they sell out. $349.97 is clearance price
Built in spatial modeling speakers.
Great monitor for Retro gaming. Sturdy metal stand up/down + tilt, swivel left right
316729-0
« Reply #1041 on: Mon, 20 April 2026, 13:33:10 »
Woah, it has a cooling fan, wonder what that's for, maybe for the Power supply, since it supports 90watt power delivery over usb-C.
The spatial audio works ok, it's got 5x5watt drivers in the front sound bar, with a sensor and infrared LEDs.  Kinda mm, dun' know how to feel bout that it's watching on Tp4, LOL.
A front pop out usbc port.
HDR looks pretty good. Not as good as TVs due to smaller peak area, buhhhh still gud.
Overall for $350, you can't do better.
Running a hot cycle now and will calibrate afterwards.
But it looks like black point is done well out of the box, and the dithering algo is tuned well. Prolly samsung Pixel DACs/ Drivers, which are top notch.
« Reply #1042 on: Tue, 21 April 2026, 10:05:42 »
HDR performance,  Looks good.  Of course the tonemapping algorithm isn't as strong as Giant TVs with bigger engineering teams, but still very good. You can't get anywhere near this for $350 anywhere else.
SDR Calibration a bit weird, but that's normal these days. ~242nits 100% full field.  If it had a better tonemapper it could do more, buhhh it is what it is.
Mild disappointment that there's no calibration settings for HDR,  probably burried in the service menu that no one has unlocked yet.
« Reply #1043 on: Tue, 21 April 2026, 17:48:13 »
Does anyone ever actually use DLSS? I don't know of a single person who actually uses it or likes it's effects, and yet they push it in every single modern PC game as a feature.
« Reply #1044 on: Tue, 21 April 2026, 18:27:39 »
On 4K monitors most people use DLSS or FSR.
Offline Darthbaggins
  • PC Cannibal
« Reply #1045 on: Sat, 25 April 2026, 21:24:23 »
Just got my MSI 274Q - replaced the 272Q I had for 24hrs before it's firmware bug (stuck in OLED care 2.0 loop).  OLED is life now, love it.
