Author Topic: Gaming PC Parts discussion thread.  (Read 844561 times)
Offline phinix
Re: Gaming PC Parts discussion thread.
« Reply #350 on: Thu, 13 March 2025, 14:58:00 »
it looks like this.
312655-0
« Reply #351 on: Thu, 13 March 2025, 15:05:30 »
Check if the OS's night light setting and stuff is off.
If not that. It might be something on the LG, game optimizer, dynamic processing settings.
See if the Contrast / Brightness setting helps at all.
« Reply #352 on: Thu, 13 March 2025, 15:08:12 »
It might be DSC,
You can use CRU to set the EDID, and then save, then reboot.
The total chunk has to be blank. Other boxes unchecked like in the photo. Don't touch the settings outside the display stream compression  yellow box.
312657-0
Offline phinix
« Reply #353 on: Thu, 13 March 2025, 15:14:01 »
It might be DSC,
what is that app?
« Reply #355 on: Thu, 13 March 2025, 15:16:39 »
Use WhatColor to check the pixel value.
If it's matching Tp4's , then the GPU/Windows should be outputting the right color, and it is more likely the TV side.
All else fails, DDU, try re-installing driver.
312659-0
Offline phinix
« Reply #356 on: Thu, 13 March 2025, 15:17:49 »
I got this..
312661-0
« Reply #357 on: Thu, 13 March 2025, 15:23:12 »
I got this..
Yea you're in the right menu.  Disable the dsc options like in my photo, and change chunk to blank.
Also try 120hz instead of 144, sometimes Displays use different maps between refreshrates.
Is VRR turned on ?
Offline phinix
« Reply #358 on: Thu, 13 March 2025, 16:04:32 »
I got this..
Is VRR turned on ?
vrr where?
« Reply #359 on: Thu, 13 March 2025, 16:22:06 »
I got this..
Is VRR turned on ?
vrr where?
Before you try VRR, none of the other stuff worked? DDU etc?
Try unplugging and replugging the hdmi after the pc has already booted and you've logged in.
VRR amd setting is here. Gear icon, Display. If it says not supported, you need to change some setting on the LG.
For example, I have to change to game mode on my samsung for vrr.
312663-0
Offline phinix
« Reply #360 on: Thu, 13 March 2025, 18:03:51 »
I got this..
Is VRR turned on ?
vrr where?
vrr is enabled.
Re-plugging hdmi did not work. Could it be cable itself? I was fine for nvidia card...
How can I make sure I entirely uninstalled nvidia drivers, in case it had something to do with the problem?
« Reply #361 on: Thu, 13 March 2025, 18:16:25 »
DDU is the uninstaller.
Download the latest DDU verison, then boot into safe mode, and run it.
« Reply #362 on: Thu, 13 March 2025, 18:20:35 »
The display setting screen looks like this ?
312669-0
Offline phinix
« Reply #363 on: Thu, 13 March 2025, 18:26:23 »
drivers uninstalled.
Now, apart from that there are no drivers and screen is in 720p odd resolution, colors are fine, like before card installation.
So now will try to install adrenaline...
« Reply #364 on: Thu, 13 March 2025, 18:27:16 »
Did you do it via DDU? if it doesn't work, give DDU a try in safe mode.
Offline phinix
« Reply #365 on: Thu, 13 March 2025, 18:32:49 »
Yes, DDU. I did not do safe mode but it worked as it uninstalled everything and colors went back to normal.
Now Adrenaline is installed and it came back :(
Everything is pale, also like heavy sharpening was applied.
« Last Edit: Thu, 13 March 2025, 18:38:47 by phinix »
Offline phinix
« Reply #367 on: Thu, 13 March 2025, 18:39:30 »
pale AND saturated?
sorry, my mistake, pale. also like heavily sharpened, like when you apply sharpening to a photo when editing, it becomes grainy and pale.
Offline phinix
« Reply #369 on: Thu, 13 March 2025, 18:41:44 »
Is the C4 hdmi in PC mode?
yyyyy.... wait....
Offline phinix
« Reply #370 on: Thu, 13 March 2025, 18:50:31 »
Duuuuuuuude!
I switched on 4:4:4 pass through and it worked! (on tv settings ext devices...)
I knew how to get in PC mode when had CX.
How do you do that on C4?
« Last Edit: Sun, 02 November 2025, 17:02:37 by phinix »
« Reply #371 on: Thu, 13 March 2025, 19:00:16 »
Firstly, Phinix must admit AMD makes the most greatiest GPU on the planet, superior to Ngreedia in every way, and it was Ngreedia's fault that Phinix's TV did not properly respond to AMD's incalculably uncontainable greatness.
 :D
« Reply #372 on: Thu, 13 March 2025, 19:02:21 »
The reason the TV wasn't doing it right is because if it was taking in 4:2:0, it has to do chroma upsampling, and then sharpening.
Offline phinix
« Reply #373 on: Thu, 13 March 2025, 19:02:32 »
 :D
Weeeeeelllll... maaaaaaaaybeeee..... donno... need to use it for longer.
Now, where is my Dead Space...
nvidia 3070    - ave 30fps
amd 9070 XT - ....
« Reply #374 on: Thu, 13 March 2025, 19:04:54 »
In the old LG menu, you had to rename it PC to make it pc mode, the new menu you just turn on 444 passthrough, Tp4 assumed phinix already did that. But forgotten he's new to C4.
Tp4 had owned a G3 briefly when shopping during samsung s90c vs G3.
Offline phinix
« Reply #375 on: Thu, 13 March 2025, 19:14:16 »
Yeah, C4 is different than my old CX.
But cool, it works.
How can I display fps on screen while gaming with AMD?
Nevermind, I used Steam fps. Jeeez, DLSS quality, high settings - ave 80fps.
3070 had 30fps.
70fps with RTAA, with everything on Ultra! 3070 could not handle RT and Ultra settings.
GPU temp during 4k Dead Space gaming - 80C max, plus 3x quieter than 3070.
So to sum up:
Dead Space (4K, DLSS quality, high settings (max), RT on) ave fps:
3070 = 30fps
9070XT = 70fps
312671-0
« Last Edit: Fri, 14 March 2025, 19:51:48 by phinix »
« Reply #376 on: Thu, 13 March 2025, 19:35:25 »
It should do well in Ray tracing.
You can also replace the in game dlss with later versions of FSR, but this is a can of worms.
I think it had FSR2 natively.
« Reply #377 on: Thu, 13 March 2025, 19:38:05 »
Also, when you clean it next time, have the PTM7950 ready.
Don't forget you can get another 10% performance from undervolt+ overclock. It's really easy now.
« Reply #378 on: Thu, 13 March 2025, 22:06:23 »
NE PC parts Tp4 should buy from the Canada just in case?
« Reply #379 on: Fri, 14 March 2025, 09:21:44 »
Spent all of the previous evening researching "The Best Thermal Pads."
It would seem Aairhut is the top one buyable, BUHhhh, not legit sourced.  So There's really just the Thermalright Odyssey II, and Arctic TP-3 which are assured from "Legit Seller."
Thermal Grizzly pads are too overpriced for contention.
Also mentally Leaning, Thermal Putty, buhhh, it's just too icky, and again, source problem..
« Reply #380 on: Fri, 14 March 2025, 10:50:29 »
3070 had 30fps.
AMD has their own overlay now, you go to hot keys in adrenaline and set it up.  Some other overlay tools can actually add input latency, particular if you use them to monitor GPU wattage.
What case is that. Are the top fans exhaust?
Is the bottom removable for a deshroud mod ?
Offline phinix
« Reply #381 on: Fri, 14 March 2025, 15:15:35 »
3070 had 30fps.
Its Coolermaster NR200p.
Yes, top fans are exhaust.
Bottom of the case? Yes it is removable.
« Reply #382 on: Fri, 14 March 2025, 15:26:42 »
Yea that's perfect for Deshroud modding.. No bottom, maximum air hole.
« Reply #383 on: Fri, 14 March 2025, 16:22:11 »
Do Not Buy.
Trash level quality, Trash level design.
The internal strut providing the male end counter force is too thin, it compresses, and it's very difficult to get the pins to fully seat into the motherboard, You have to apply a dangerous amount of force.
This not only indents/ breaks that strut slightly, it's also not quite enough to fully seat the adapter.
The internal PCB is also indented/bent very close to where side pins are, one could easily imagine a cracked joint here or trace.
312675-0
« Reply #384 on: Fri, 14 March 2025, 18:43:40 »
This advertising is just,
What are they so happy about holding a pcie SSD in their hands?
I mean, you know it's just stock images they purchased with the hand pose, but what was the thought process behind making the image, what exactly are they trying to convey?
312681-0
312683-1
Offline phinix
« Reply #385 on: Fri, 14 March 2025, 19:51:06 »
But cool, it works.
3070 had 30fps.
So to sum up:
3070 = 30fps
9070XT = 70fps
Alone In The Dark (4K, Settings Cinematic (max), FSR off) ave fps:
3070 = 25fps
9070XT = 60fps
« Reply #386 on: Fri, 14 March 2025, 22:03:21 »
Hrrm... It seems like the 7900gre in this used Black Friday PC is already experiencing pump-out. If the original owner only got it in december, that's only 4 months of use.
GPU wattage is getting out of hand.
« Reply #387 on: Sat, 15 March 2025, 09:44:05 »
Headsup on PTM
From reliable sources,  All mid-range cards and above have switched to PTM as stock paste.
NO NEED to buy additional PTM for cards.
« Reply #388 on: Sat, 15 March 2025, 20:54:29 »
Who the heck buys these Amazon prebuilts..
The pricing is terrible.
312694-0
312690-1
312692-2
« Reply #389 on: Sun, 16 March 2025, 11:48:05 »
Something is deeply wrong with a person when he sits in silence, listening to a single computer fan, flipping between 50rpm increments to subjectively characterize the perceived noise.
Oh wait, it's just TP4.
Really, think what has to happen to produce this kind of crazy, he has to be so detached from the natural world, for such an inane action to seem like a reasonable thing to be doing.
« Reply #390 on: Mon, 17 March 2025, 09:27:35 »
The primary reason PCs look bad these days is simply, Too many fans.
Circles are good, but too many circles, it just looks crowded.
Unfortunately fans are the money maker, so these cases are really just designed to sell people m0ar fans.
Also, when did pci slot covers get so expensive.
« Reply #391 on: Mon, 17 March 2025, 13:28:05 »
LED strimer cables only look good in the dark, off angle. when you can see the ends, they look jank.
Offline phinix
« Reply #392 on: Mon, 17 March 2025, 13:40:10 »
I always found leds to be iffy, never looked like you would like them to look like.
I was a modder for many years and always tried to hide led lighting, so it would only give a glow without source of light. Very hard to achieve...
« Reply #393 on: Mon, 17 March 2025, 14:24:21 »
Tp4 is old enough to remember CCFL stick lights with the hot as hell balast connect boxes.
« Reply #394 on: Mon, 17 March 2025, 16:37:51 »
After testing all the fans.
Arctic p12 max has the highest noise vs performance profile.
The measured noise level was about the same between all fans in DB, but VERY-different in perceived annoyingness.
The Nova, had a high pitched wind noise.
The Scythe, apart from the broken bearing, noise was fine, but if quality control is this bad at $20 a fan, not going to bother.
The Arctic also came with one with a bearing that's not as good (not broken like the scythe, but a low chuchuchuchu), but it's acceptable at $10 a piece, ordered a replacement, the new one's fine..
These are the only legit 3000rpm'rs on Amazon.   2000 has more options, but not enough headroom.
Performance is 5 Celcius better than stock fans at ~200 less rpm.
Poortitude certified Jankdevil 7900xtx.
:D
312706-0
Offline phinix
« Reply #395 on: Mon, 17 March 2025, 19:18:40 »
Jeez, I remember in early 00s we all had flavor for watercooling and everyone was trying out all possible fans, it was a total show, search for best fans for radiators...
Offline Leslieann
« Reply #396 on: Mon, 17 March 2025, 19:29:38 »
How are you powering and controlling the fans?
Off mobo with software or using an adapter off the gpu? Just curious.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
Ergo Clears, custom WASD caps
| Das Pro
Costar model with browns
| GH60
« Reply #397 on: Mon, 17 March 2025, 19:35:21 »
Normally you can do that, they sell adapters for it to connect to the card fan port.
The problem in this case is the red devil xtx bios hard locks to 35% pwm starting point, which is way too high for desktop 3000rpm fans that ramps up to 1650rpm.   You can use 0rpm idle, but that's bad for cards.
So Tp4 is using a motherboard adapter and fancontrol software, which works amazing, it's so configurable.   For example, after gaming, you can set it to decrease pwm by 0.5% per second, giving you a 60second cool down period post gaming.  That's really cool.
There's no reason not to use fan control, it's so good, you can read 2 sensors at the same time, and have it respond to the highest sensor.
So for example, if you have a higher CPU only load, the fans can respond to that independently of GPU or respond to a high GPU only load, any reasonable logic you need, it's got it..
That's way better than reading a motherboard sensor, because those sensors have a huge time lag, AND, they don't have a very high dynamic range (temperature delta)  for you to accurately tune the fan curve.
Offline Sniping
« Reply #398 on: Tue, 18 March 2025, 01:31:15 »
finally acquired an amazingly low priced 7800x3d system to pair with my 4080s. paid 550 with no gpu and came with a quality PSU, 4 silent wing fans and it’s an SFF build. it’s mostly white so doesn’t really go with the 4080s, but it was a deal I couldn’t pass up.
