Author Topic: Gaming PC Parts discussion thread.  (Read 105481 times)
Re: Gaming PC Parts discussion thread.
« Reply #650 on: Sat, 14 June 2025, 17:20:22 »
This is pretty daunting for TV shoppers.
In entry lvl LCDs which are advertised as Quantum dot, they have used different arrangements of 1 to 2 dots of the 3 NOT being QD.
For example, Tcl's new qm6k, it doesn't have a QD red, it's KSF red.
Kind of a big deal. Notice the drop in color purity in the second image.
« Reply #651 on: Sun, 15 June 2025, 19:02:29 »
My PSU burned out last night, apparently. Tower PC won't power on today, hopefully it didn't fry anything else.
It's an excuse to upgrade my PSU and case I suppose. More **** I need, but cannot really afford at the moment  :(
« Reply #652 on: Sun, 15 June 2025, 19:13:32 »
Get a good one or the Gpu coil whine will be bad.
« Reply #653 on: Mon, 16 June 2025, 04:10:39 »
Well, shiver me daisies. My ***** is fried.
PSU did something uncalled for and burnt out the mobo on my main rig in some sick suicide pact. I seriously cannot afford an  all-new PC now, so I may as damn well get a new mobo, alongside a psu (maybe some other sweet **** too). CPU, GPU, RAM all seem fine (at least they are recognized working in a system that cannot run them)
Man life is relentless. I thought I had myself a workhorse. Been good to me for 13 years, yessir.
but SHE CAN BE REBUILT... STRONGER, AND (ever-so) slightly FASTER THAN BEFORE!
I will make her whole again. Better even!
« Reply #654 on: Mon, 16 June 2025, 04:53:13 »
hold me hostage to upgrade?1!? **** YOU! IVY BRIDGE IS STILL RELEVANT!
gonna make this work, my 'lil Frakenstien...
« Reply #655 on: Mon, 16 June 2025, 08:15:21 »
If you're hardline-ing on Ivy,  delid the chip, then you can push 4.8ghz easily. Get 2x8gb 2400mhz ram because ivy can support it.
Get liquid metal for between the die and IHS. Regular paste between the ihs and heatsink
You don't need a new heatsink, you can get away with a cheap single tower after delid it will be fine.
Tune fan curve with "Fan Control" app, great app.
Ivy is good for everything outside of pr0-g4m3r 600fps, and the modern games that are really badly designed that chews up cpu, helldivers, halo infinite.
But without 4.8ghz
, it's going to struggle, both on memory bandwidth and raw ipc.
Tp4 WOULD HESITATE to rescue an IVY, because with all the parts involved, You can buy, as difficult and unattractive a proposition, an AM4 build.  Used 5700x can go for decent cheap.
Of course TP4 is highly AGAINST AM4,  You should spend $1500 to get an AM5, amd 7700 (nonx, refurb cpu, $160)+9070xt build.
$160cpu
$730 9070xt
$150 B650 mobo
$80ram
$80psu
$40heatsink
~$1240 + old case + old fans
~$1500 if you want xpensive fans/case/rgb/cable extensions
« Reply #656 on: Mon, 16 June 2025, 08:32:22 »
Microcenter 7700x+b650+32gb ram bundle for $350 is back .
« Reply #657 on: Fri, 20 June 2025, 18:59:08 »
And the rebuild has begun. My goal is to have my tower at least running by the middle of next week. I'm still waiting on my new PSU to arrive in the post, but I've scrounged up a few local deal parts for fantastic prices.
Here's my current system:
EVGA RTX 2070 SUPER FTW3 Ultra --> RTX 3080 (mobo can run 4k series but the cpu bottleneck wouldn't be worth it)
i7 3770K oc'd 4.2GHz --> Same
P8P67 REV 3.1 - Rev.09.B3 --> ASUS SABERTOOTH Z77 (improved socket, comparability, and all-around bus speeds)
32 GB DDR3 @ 1067MHz --> trying to find 32Gb 2133/2400 sticks for cheap
650w PSU --> 850W
and finally, a new case. The Fractal Define 7 is top of my list, but expensive. Plan on keeping the case and GPU for my next build anyway. Anyone have a full-tower ATX they would sell for cheap??
This will build will be the theoretical limit of what Ivy Bridge is capable of, and I wanna complete the build just for the sake of that. Not because I should, but because I can.
I got a used Sabertooth mobo for $60, and Noctua D15S BRAND NEW for $70 already with the PSU on the way
NOCTUA ON THAT THANG  :p
« Reply #658 on: Fri, 20 June 2025, 19:31:12 »
There are no 32gb 2400 sticks. There's only 2x8gb 2400. the 3770 wouldn't be able to run 4 sticks at remotely close to 2400mhz. probably 1866 tops.
The 3770k oc at 4.2 is too low.
If you don't want to delid, you can actually just Copy a conservative voltage setting for 4.8ghz from the internet for an Asus board of that generation.
Just don't test it in Load, just play games, it shouldn't go over temp.   You just can't fully test stability without delid, but it doesn't really matter since it won't hit that in normal games, and you don't really care about absolute stability for games anyway.
In anycase,  This is not a great way to spend money.
Because for that amount, you're already more than half way into a brand new AM5 system.
Absolute cheapest am5, $80 mobo, $150cpu, $50 ram,   And this will run around 4x-6x what 3770k would do @ 4.8ghz.
« Reply #659 on: Fri, 20 June 2025, 19:59:35 »
The z77 socket does enable the 3770k to run up to 2400mhz, and they do exist in 32gb 4x8Gb packs, and the z77 is the only socket that allows the cpu to do that. Even then, I think I'll need to get some specific bios drivers.
https://www.gskill.com/product/165/182/1532501792/F3-2400C11Q-32GSR
https://www.gskill.com/product/165/173/1532071653/F3-2400C10Q-32GTX
Like I said, this is mainly for fun to build the ultimate 3770k build that pushes everything into bottlenecking.
The price difference between doing this fun lil project and doing a total new build is like $600-700 vs $2000-2400
and I plan on upcycling the GPU, PSU, and case to my future build which will almost certinally be a Nova Lake build in about 2 years time.
the z77 is a very interesting board allowing some advanced parts to be grafted onto my Frankenstein's Monster
« Reply #660 on: Fri, 20 June 2025, 20:26:45 »
Guaranteed you won't be able to run 4x8gb sticks at 2400mhz.  it will run 1866 tops, with relaxed timings, and for that you'd have to push the IMC voltage pretty high, and you lose FPS, on an already lower IPC Cpu.  2400mhz will top out at 2 sticks.
Tp4 is not judging how NT may be justifying this,  but it is resolutely against economic sense.
AM5 is faster, and "Not expensive," if you go the the low power route.
And since enough of the old stuff was already broken, the Performance to Power ratio high lean towards AM5.
It's not $600-700 if you don't upgrade the GPU.
$80 am5 mobo, $150 7700 used, $50 5600mhz ddr5 ram, cheap $20 thermalright cooler, more than adequate + $50 power supply,
It's only 80+150+50+20+50, $350 for an entry lvl am5.   4x the performance minimum (cpu bound scenarios).
If you want the GPU 9070xt or 5070ti, add $730 to $830. You're only at $1080 to $1180
If you MUST HAVE NOSTALGIA,  well, it is what it is. Tp4 not judging. Just being clear about the numbers.
« Reply #661 on: Fri, 20 June 2025, 20:38:48 »
The 3770k maxed out at 4.8ghz is about 70% of a 2700x on this graph. Or, 40% of a 9800x3d.
Whereas for roughly the same cost, a 7700 used cpu will be 92-95% w/PBO boost as fast as a 9800x3d at 1440p
"Retro nostalgia". That's fine. But the math is as stated.
« Reply #662 on: Sat, 21 June 2025, 08:00:12 »
HDMI 2.2    96gbit
This should do , 4K 288hz uncompressed w/ timing adjustment.
That's pretty exciting, although, GPUs haven't gotten fast enough to really even max out 4K fidelity. Shading that many pixels is already too expensive to consistently hit 60hz.
The clipping point is probably 100x the gpu power we have now. At which point, it would be close to movie quality cgi.
Wonder how long they can make these cables and how fragile they would be.
Those 80gbit dp 2.0 cables pretty much only work ok at 3 feet.
In the end, will we really reach that point before burning out the planet with 1Kilowatt gaming pcs.
Offline phinix
« Reply #663 on: Sat, 21 June 2025, 13:15:28 »
I use i3 12100 with 9070XT gaming in 4K - I never seen reason why I should go for more expensive CPU.
12100 | 9070XT | 2TB SSD | ROG STRIX B760-I ITX | 32GB RAM | SFX 850W | NR200p | Ruark Audio MR1 Mark II | LG OLED 42C4
Realforce 87u55 | CM QuickFire Rapid MX Blacks | Filco TKL 85g Gateron Oil Kings | Tiger Lite 85g Oil Kings | Logitech Pro Superlight
GSA: Retro High-light  HSA: Hyperfuse  XDA: Canvas  PBS: MV Classic
« Reply #664 on: Sat, 21 June 2025, 13:20:07 »
It depends on the game and resolution, but it would be 15% to 45% lower fps vs 9800x3d.
Offline phinix
« Reply #665 on: Sat, 21 June 2025, 14:48:13 »
Its £420 in UK! NUTS!!!
My i3 for £60 give me 70fps in 4K with max details with 9070XT, any game I pick. Nobody can convince me to buy more expensive cpu.
« Reply #666 on: Sat, 21 June 2025, 20:30:15 »
Guys you don't have to buy 9800x3d.
Tp4 would get, 7700 (used) $150-170, $150 AM5 board, $70 ddr6000 cl28 ram. This is 92-99% as fast as 9800x3d in GPU-Bound scenarios.
« Reply #667 on: Sat, 21 June 2025, 22:07:03 »
AI cheats in sonic all star racing transformed.
Tp4's so mad. Mean, it's normal for kart games, but /grinds teeth.
Playing Sonic, fastest character + ALL Star pickup, AI is still faster on straights. what is this bbbsssss
« Reply #668 on: Mon, 23 June 2025, 00:54:23 »
ugh, everyone I have told my 3770K ultimate build dream to has told me it is stupid and a waste of money  :-\
Well, I needed the PSU and new mobo anyway, and I'll just replace the case fans and delid the cpu and call it a day. Anything else beyond just getting my tower working again is needless, especially running such an old cpu.
As much as I'd love a 3080, it just doesn't make sense to drop $400 on something that would be suffocated in that build when my 2070 S does a fine job for now
maaaan, being poor really sucks. You'd think I'd be used to it by now. I just don't understand how everyone else does it? I did all the right things people say you need to do to be successful in life, and still fail at every attempt to improve my finances. Like my brain is broken or something.
« Reply #669 on: Mon, 23 June 2025, 05:12:27 »
You do it for the RETRO.  It makes 0 monetary sense otherwise.
People build $2000 socket 939s.  $2000 on neogeo.
« Reply #670 on: Mon, 23 June 2025, 05:38:51 »
yes, I also own a Neo Geo AES
« Reply #671 on: Mon, 23 June 2025, 14:14:00 »
Zen 6 rum0rs. + 30-40%
Too good to be true. But honestly, even for esp0art, do you need THATTTT many frames?
If someone can't do what need do @ 480hz oled, 480fps, is 1000fps gon' make um' do it?
Offline Sniping
« Reply #672 on: Mon, 23 June 2025, 17:51:02 »
From the industry standpoint I feel that they basically try to sell you whatever fancy tech they can produce to make another sale or to make your current gen latest tech into last gen tech. They do say the difference is noticeable when you double your frame rate, so like 60 to 120, 120 to 240 etc. not that it'll make a difference to anyone's performance
« Reply #673 on: Mon, 23 June 2025, 17:57:20 »
Something like 10,000 fps is noticeable at high pan rates, but since the "game" is not built around this "mechanic", it's mostly a bit wasteful.
« Reply #674 on: Wed, 25 June 2025, 15:46:38 »
People using ultrawides for internet.
's just not right, unusuable.  It's almost like going back to those 21" 5:4 lcds.
Offline phinix
« Reply #677 on: Thu, 26 June 2025, 07:20:59 »
I'm actually more optimistic than the Intel doomers, as the IPC isn't that bad, if their x3d thing works at all, I think 30-40% from 285k is easily cover-able.
I don't think that will catch AMD's more mature design, but it should come within 20%.
As a stock, is that enough, no because they got all these expensive factories that aren't utilized.
« Reply #678 on: Thu, 26 June 2025, 14:05:44 »
These articles claiming switch lcd 100x slower than oled. That's impossible, oled is not that fast.
Oleds go down to 5ms with 144hz,  2ms at 360hz, 1.5ish at 480hz.
Switch lcd is only 36-45ms.
« Reply #679 on: Fri, 27 June 2025, 17:17:36 »
Why did they ever advertise oled as infinity:1 contrast ratio.  Now everyone thinks that, when it's simply not possible.
They need to qualify the various viewing conditions.
Pixel on vs pixel off, infinity:1 under ansi checker box
Pixel on vs pixel off, real world 50% fill
Pixel on vs pixel off, in room reflection w/ refraction
Pixel on vs pixel off, in room reflection w/o refraction
Pixel on vs pixel off, w/ glass w/o glass
Subpixel stack refraction
Subpixel leakage
Under most conditions, it's not infinity:1
« Reply #680 on: Fri, 27 June 2025, 20:58:25 »
Wifi 7, honestly if it's doing 2ish gigabit, that's nearly as much as you'd need for HDD storage without clusters.
« Reply #681 on: Sun, 29 June 2025, 08:42:56 »
4K gamestick what a piece of crap. Overheats, game freezes. They sell these things for $40, but you'd need another $25 in parts to "fix" it.
Offline Leslieann
« Reply #682 on: Fri, 04 July 2025, 10:41:16 »
Rumors are starting to circulate that new Intel is also degrading.
Doesn't matter how good if it doesn't last 2 years.
I'm getting very hyped for Nova Lake.
52 Cores baybee!
https://www.tomshardware.com/pc-components/cpus/intel-nova-lake-specs-leaked-up-to-52-cores-and-150w-of-tdp-for-intels-amd-zen-6-rival
what do ou need 52 cores for?
Yep
Only under very limited circumstances can you actually take advantage of so many cores, most stuff you will do on a desktop simply can't multi-process that well (and never will without major technological leap) meaning the only other use is multiple process and your system only has so many of those running at once, most of which are very small and sit idle 99% of the time. Much more than a dozen and you start having idle cores and/or cycling loads around between them.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
Ergo Clears, custom WASD caps
| Das Pro
Costar model with browns
| GH60
« Reply #683 on: Fri, 04 July 2025, 18:32:49 »
This is the problem with radical new designs and process changes in a short amount of time.
They really should slow down, FOCUS.
Honestly they should just stop making any TSMC CPUs, unless they are selling off their own fabs.
It doesn't make any economic sense to be powering up Taiwan to continuously kill American process competitiveness.
That is just really stupid.
Offline phinix
« Reply #684 on: Sat, 05 July 2025, 10:29:58 »
Guys, what do you think - what nvidia going to make with next 60xx series?
Is it going to be bull**** again, or are we gonna get a proper performance increase from 50xx series? Proper I mean like 40-50% increase, not bull 10-15%.
Am I correct saying that they cannot do die shrink anymore?
Offline Leslieann
« Reply #685 on: Sat, 05 July 2025, 10:43:09 »
Moore's law is dead, stop expecting those same increases.
Also. Nvidia has learned they can eek out minimalistic updates and people will still buy it so as long as AMD is behind they will only offer minimalist updates from now on unless they have some major breakthrough. Worse still we're the backup, they only give us leftovers from whatever industry is the new thing such as crypto or A.I.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
| Das Pro
| GH60
« Reply #686 on: Sat, 05 July 2025, 22:36:00 »
We could expect those increases if it weren't for AI buying up all the chips.
The other end of this is, it's a frivolous territory of electricity use just to play video-games.
« Reply #687 on: Sun, 06 July 2025, 07:18:48 »
Ps5 liquid metal failures.
Tp4 can confirm that liquid metal actually does have dry spots over time.
This happens quite frequently on hacky diy liquid metal laptops where they didn't galvanize the copper.
It also happens on desktop with the ihs + delid.  It's just a matter of time, this stuff doesn't last forever. 2 years TOP. swap it out people.
« Reply #688 on: Sun, 06 July 2025, 07:33:49 »
Zen 6 7-ghz rumors.  It's insanity, absolute insanity, nearly pees pants.
« Reply #689 on: Thu, 10 July 2025, 12:17:03 »
Reverse blade fans should BE ILLEGAL.
They're god awful in the majority of pc cases.  Pulling air against any grill, even with big holes is extremely noisy.
Anything higher than 600rpm, they make a choooooooo noise.
« Reply #690 on: Fri, 11 July 2025, 15:22:58 »
Well, Project Lifesupport is a full go. I officially have all the upgrades on the way, except for a main HD replacement.
Sabertooth z77/ 850W PSU/ a KILLER Noctua cpu cooler/ some case fan upgrades
Gonna do a full disassemble and deep clean including fans, replace some case cables, delid/move to new home/repaste the cpu, replace existing PSU that powers off when the cord jiggles
This rig just needs to last 1 more year or so
« Reply #691 on: Fri, 11 July 2025, 21:00:46 »
What is up with 40gbps ssd enclosures.
Why do most of them top out at 3.3Gbps, that's only 26gbps.
Offline Kavik
« Reply #692 on: Fri, 11 July 2025, 21:44:58 »
What is the recommendation for monitors these days? I know TP4 will have opinions on this.
I'm thinking of a 1440p OLED, but there's only one or two models that are 24". Everything else is 27". I'm not sure how much refresh rate matters above 144hz (what I currently have).
Also, I'm not sure if ultrawide would be a good idea. I currently have a triple monitor (all 16:9) setup on monitors arms, but I never use all three monitors for games (I tried it once out of curiosity, but the setup was annoying, and everything looked really bad because it was so stretched with peripheral things appearing too close).
Offline Kavik
« Reply #693 on: Fri, 11 July 2025, 21:47:02 »
Hell, yeah.
I just stuck my 3770K system in a new case. I killed a RAM stick trying to fix the heat spreader, so I've ordered a cheap used pair to replace it. I need to change the cooler if I don't want to damage the RAM again.
« Reply #694 on: Fri, 11 July 2025, 22:58:33 »
This is what I'd get, but it is very suited to my specific uses of immersive solo gaming and movie watching:
https://www.newegg.com/samsung-ls32bg852nnxgo-32-uhd-max-240-hz-odyssey-neo-g8-va/p/N82E16824027121?Item=N82E16824027121
https://www.newegg.com/msi-mpg-321curx-qd-oled-32-uhd-240-hz-metallic-black-rgb/p/N82E16824475451?Item=9SIAFVFKFD3528
also got dang expensive  :blank:
« Last Edit: Fri, 11 July 2025, 23:03:00 by noisyturtle »
« Reply #695 on: Fri, 11 July 2025, 23:17:43 »
If you're married to sitting at a desk.  240hz 32" 4k qd-oled 16:9 is the practical solution.
Ultrawide oled is not recommended, it's pretty easy to cause uneven pixel wear if you use only portions of the screen.
You might consider 43" qd-oled or oled if your desk is more than 2 feet deep. These go up to 144-165 depending.
You should get a motorized standing desk if possible. This gives you alot of flexibility, and long run, less back pain.
The thing about the 32", is that at the moment, there're some issue with implementation involving win 11/ drivers/ DSC.  It's really not as seamless as it should be.
You have to research it per model.  Even if they all buy the same samsung or lg panels, the drive package they're tied to may or may not work in the configuration you're after.  You might want a monitor that can run without DSC to get the best image quality, but then, will it be compatible with the GPU, specific drivers might break something, or you have to buy 5 or more cables to get one that can actually push all 48gbps @ the length you require.
HDR is still not fully solved.
You can start with price, but caveat, does it work properly, does the drive package show bad dither handling resulting in banding in 8bit/10bit.
You have to have clear stated goals.  And unfortunately, you can't have these goals, if you don't invest quite alot of time educating yourself on what constitutes A Superior image.
Just getting to the point where you can ASK THE RIGHT QUESTIONS, is a journey all its own.
The marketing, numbers, delta-e, etc, unfortunately are mostly made for dumb people. They're not very informative.
If they advertise, 240hz, ok, but if it's really blurry in motion, what's the point.  If they advertise xxx-bit signal, xxx-bit processing, ok, but if it still shows really bad banding, looking at you LG,  then what's the point.
If they advertise Delta-E <XX,  selling delta-e is like selling Yardsticks to people who want a baseball bat, it's inappropriate outside of proper context.
It's enough to say you can't just throw money at this.
« Reply #696 on: Sat, 12 July 2025, 14:08:37 »
SSD speed rates are kind of BS when you can't even copy files that fast in windows.
With the Teracopy multithread top speed is only about 3.3-3.6 GB/s sustained on 4thread.  If ne1 has the paid version, maybe it can go faster with more threads?
Someone mentioned Fastcopy can do 5GB/s, need to try this out.
https://akiba-pc.watch.impress.co.jp/docs/topic/special/2005307.html
« Reply #697 on: Sat, 12 July 2025, 14:30:19 »
Ohhhh snappp.  This japanese program guy's window xp style GUI copier works.
Saturates SSD's bus. Full speed. 6.5 GB/s average
« Reply #698 on: Sun, 13 July 2025, 03:18:52 »
Why are they so stingy with the usbc ports?
How much can these chips possibly cost?
« Reply #699 on: Sun, 13 July 2025, 09:13:50 »
So on Tp4's older 10Gbps ssd enclosure,  it can sustain about 700MB/s for 10 seconds, then drops to 400MB/s, but then it will cut out around 40GB worth of writes.
Is the Enclosure bridge chip overheating? The SSD is fine, since it's well under the max heat load with only 400MB/s writes.
Has anyone encountered this.
