Author Topic: New Realforce 87U 10th Anniversary with couple of issues  (Read 6586 times)
Offline durainello
    • Free cheap and fast International shipping solution to fellow Singaporean.
« on: Mon, 14 January 2013, 17:18:12 »
I had gotten a new Realforce 87U 10th Anniversary. I had discovered couple of issue, hoping to get some answers here.
Offline absyrd
  • CPT HYPE PADAWAN
Re: New Realforce 87U 10th Anniversary with couple of issues
« Reply #1 on: Mon, 14 January 2013, 17:19:26 »
Push it down?
Offline durainello
« Reply #2 on: Mon, 14 January 2013, 17:31:20 »
I tried, my question is , is this normal for the cover to move around.
Offline daerid
    • Rossipedia
« Reply #3 on: Mon, 14 January 2013, 17:37:20 »
Yes it is. I've owned 3 87u's, and all of them had top covers that moved slightly. It's not a manufacturing defect.
*Edit* Actually, now that I think about it, none of them moved vertically. They only had a slight amount of horizontal play.
Offline durainello
« Reply #4 on: Mon, 14 January 2013, 17:40:03 »
How about the super shaky / loose left Ctrl. Kinda like buying a Lamborghini with squeaky door.
Offline oneproduct
  • @Ubisoft
« Reply #5 on: Mon, 14 January 2013, 17:49:59 »
Mine has both a bit of cover movement, though like daerid said it was horizontal rather than vertical, and the shaky left control key so it's not only you.
Layout: Colemak
Offline durainello
« Reply #6 on: Mon, 14 January 2013, 17:51:34 »
At least that eased my mind, thought i gotten a lemon.  :))
Offline blackrim
« Reply #8 on: Tue, 15 January 2013, 10:22:31 »
I don't have a loose cover but do have a loose left ctrl
Realforce TKL 45g | HHKB (white and black) | Filco TKL blues | Das Ultimate browns | Kinesis Advantage
Offline bardomudo
« Reply #9 on: Tue, 15 January 2013, 10:25:24 »
I was thinking about buying a Realforce 87u instead of a Filco with Reds, but these thread just made my mind: I'm getting the Filco. It's an absurd to pay $300 for a keyboard with such kind of manufacturing issues.
Offline daerid
    • Rossipedia
« Reply #10 on: Tue, 15 January 2013, 11:15:17 »
Your loss
Offline blackrim
« Reply #11 on: Tue, 15 January 2013, 11:17:01 »
Certainly you should do what you like, but I would add that I never considered the ctrl an issue. I never noticed until I wiggled it because of this post. Also, I would add that there are a number of users here that love their realforce boards, including myself.
<typed on a realforce 45g uniform>
Offline AKIMbO
  • HHKBro
« Reply #12 on: Tue, 15 January 2013, 12:29:12 »
I've owned 3 RF boards.  All 3 boards' left ctrl keys have that uber wiggle like yours does in the video.  It's normal....but unnoticeable when typing.
| KBD75 (box reds)
Offline boost
  • BOSTMOBILE
  • NY Giants!!!
« Reply #13 on: Tue, 15 January 2013, 12:42:17 »
Had the same issue on my RF 10th AE...RF should fix that.
-Enzo Ferrari
« Reply #14 on: Tue, 15 January 2013, 13:25:14 »
why can't you guys just put some stuffing in it... or glue it.
Offline Germiphene
« Reply #15 on: Tue, 15 January 2013, 13:26:26 »
Yeah just checked all of my RF boards.  They all have a little play on the control key. My HHKB pro does not have the same amount of wiggle to it, however.   Like it's been said, its unnoticeable when typing, and not really a great reason to choose a filco over a RB.  Choose the filco if you don't like the way a topre switch feels as you type.
I may open my board up tonight to get a closer look as too why there's as much wiggle as there it in the RF.
That... Or you ALL got lemons..
Seriously, I swear you actively search for topre topics to troll, lol.
HHKB pro | RF 87U | RF 87U uni-45g | CM QFR | Steelseries 6Gv2 | Filco MT2 | IBM model M | IBM SSK '87
Offline daerid
    • Rossipedia
« Reply #16 on: Tue, 15 January 2013, 13:32:46 »
That's the one I'm typing on right now. Barely even noticeable.
Offline khaangaaroo
« Reply #17 on: Tue, 15 January 2013, 13:37:34 »
I've taken several Realforces apart. I remember the switch housing for the Ctrl key being somewhat different than the rest. The plunger is maybe a little smaller and doesn't have these two tabs that prevent it from falling all the way through if you remove the PCB from underneath it. I also remember it being the only switch on the board that had some lube on it.
I don't know why they decided to make the Ctrl key different than the rest, but it's definitely not a defect, it's designed to be that way. If it really bothers you, can take it apart and swap the switch housing with another key on the board.
Offline khaangaaroo
« Reply #18 on: Tue, 15 January 2013, 13:50:43 »
Sounds good. That way you can feel the key wiggle across all the keys on your Filco :P
In general, cherry switches wiggle a lot more than Topre. I know where you're coming from, but I don't think you should let a left Ctrl key or keyboard case deter you from trying Topre. But hey, it's your money.
I like cherry reds a lot too, btw.
« Last Edit: Tue, 15 January 2013, 13:52:50 by khaangaaroo »
Offline Yuuki
« Reply #19 on: Tue, 15 January 2013, 13:53:09 »
I noticed this problem on my rf 87 too.
But not with my rf105.
So I guess it has something to do with the del or/and the fact that you can switch it witch capslock ?
Not sure about the led since capslock and num key are well fixed, but maybe of the combination of those 2 things...
Offline Neo.X
« Reply #20 on: Tue, 15 January 2013, 14:58:31 »
I will check my RF boards tonight, didn't remember seeing this issue before.
All those keyboards will be lost in time....
Offline khaangaaroo
« Reply #21 on: Tue, 15 January 2013, 15:38:43 »
Oh yeah, that reminds me that the numlock key also has a different switch. I think it has to do with the location of the LED that determines which plunger/housing they use. The LED for the caps lock is far enough to the left that they can just use a normal switch. The numlock led is so close that they use a housing that integrate the led into the housing. And the control is kind of in between, so they used a housing that looks like it had the upper left corner sliced off. Are you guys seeing the same thing if you take your keycaps off?
Offline Yuuki
« Reply #22 on: Wed, 16 January 2013, 06:25:29 »
Yes i see the same thing (except the led on capslock is on the right, not on the left)
The ctrl plunger is different from the other two (the housing too).
Not sure why tho
Offline daerid
    • Rossipedia
« Reply #23 on: Wed, 16 January 2013, 11:33:32 »
Just pop on Dip Switch 1 (swap caps/control) and never worry about it again :)
« Reply #24 on: Wed, 16 January 2013, 13:14:14 »
I don't understand why this is even a problem.. It doesn't affect the board in any way.....
Offline daerid
    • Rossipedia
« Reply #25 on: Wed, 16 January 2013, 13:43:56 »
omg tp actually defending a topre? :D
Offline DEAD_BEEF
« Reply #26 on: Mon, 21 January 2013, 08:25:55 »
The left CTRL key on my 87U EK edition wiggles too. I noticed it a while ago. It's a little like a loose tooth, once you notice it you can't stop wiggling it around.
Offline durainello
« Reply #27 on: Mon, 21 January 2013, 08:50:54 »
Seems like the problem is common for the left Ctrl, how about the loose top cover as well, wonder is it because of only 4 tabs securing the case thus it will loosen alittle.
« Reply #28 on: Mon, 21 January 2013, 13:15:02 »
I've never been "against" topre... I just hate how people Blow it out of proportion.... it's good.... but some people mislead you into thinking it's EPIC.... which it's far from.
Offline iri
« Reply #29 on: Mon, 21 January 2013, 13:42:26 »
quick! make screenshots while his dope effect lasts!
-Ray Bradbury
Offline Jmneuv
« Reply #30 on: Mon, 21 January 2013, 15:59:30 »
i'll buy into that special control key, but the cover seems a bit too loose, like it's not fully snapped into place;
Offline daerid
    • Rossipedia
« Reply #31 on: Mon, 21 January 2013, 16:09:05 »
My newest 55g RF has a rock solid case, and I noticed while swapping it out with a white one that the top is slightly curved. This might actually help contribute to the stability of the top cover by applying extra force once the top cover is snapped into place.
My 55g AE top cover slides around a little bit, and my old 45g 87u did as well.
« Reply #32 on: Mon, 21 January 2013, 16:54:50 »
Hrrrmmm... i never checked when I had my 87, is the case abs or pbt.
Offline daerid
    • Rossipedia
« Reply #33 on: Mon, 21 January 2013, 17:02:01 »
abs
« Reply #34 on: Mon, 21 January 2013, 17:16:50 »
abs
well, maybe people could try blow drying the top side of the case slightly to put a "bend" in it like your case, and then it'd fit snugly.
