Author Topic: What are the manliest sounding switches?  (Read 5663 times)
Offline Strelok
« on: Fri, 15 February 2013, 00:11:45 »
Hardmode: No buckling springs.
Re: What are the manliest sounding switches?
« Reply #1 on: Fri, 15 February 2013, 00:12:46 »
Anything Chuck Norris touches.
Offline jabar
« Reply #2 on: Fri, 15 February 2013, 00:13:26 »
get out of here stalker
more serious: maybe Greens since they're not as bright sounding as Blues and (supposedly) louder than Whites. And I'm sure there's some pretty robust-sounding ALPS (clones) out there.
Leopold FC660C - Max Keyboard Nighthawk X8 - Ducky DK9008 Shine II 78 Edition - Noppoo Choc Mini - Cherry G80-2100HDD - Cherry G80-8113HDPUS - Plu-M87 - Leopold FC700R Ergo Clears - Deck Legend Frost 105 - IBM F PC Keyboard - IBM M 122 (Lexmark) - Apple Extended Keyboard II
Phantom 7bit
« Reply #3 on: Fri, 15 February 2013, 00:15:06 »
Replace all your springs with pen springs, may not sounds the manliest...but they will feel the manliest.
Offline jabar
« Reply #4 on: Fri, 15 February 2013, 00:16:37 »
The manliest might be a board full of Super Blacks (150 cN activation)
hop to it Ducky! (in other news, there will be full-board Dark Greys coming out soon!)
Phantom 7bit
« Reply #5 on: Fri, 15 February 2013, 00:17:36 »
Superblacks have nothing on pen springs
Offline jabar
« Reply #6 on: Fri, 15 February 2013, 00:18:24 »
Granted, but pen strings never made it into production switches!
Phantom 7bit
Offline Strelok
« Reply #7 on: Fri, 15 February 2013, 00:18:52 »
The only sound linear keys make though are bottom outs, right? My Blacks are silent if I type like a secretary.
« Reply #8 on: Fri, 15 February 2013, 00:19:36 »
We've evolved to just "manliest switches" because really, what's louder than a buckling spring? An clicky Cherry switch?
Offline jabar
« Reply #9 on: Fri, 15 February 2013, 00:19:59 »
Manliest in the sense that you can point to your keyboard when asked "do you even lift?"
Phantom 7bit
Offline Strelok
« Reply #10 on: Fri, 15 February 2013, 00:21:10 »
Optical switches that use lasers and make the PowerPoint 2007 Laser sound when pressed.
« Reply #11 on: Fri, 15 February 2013, 00:21:51 »
Well kiss my grits! You've just gone over my head!
« Reply #12 on: Fri, 15 February 2013, 00:44:08 »
Pretty sure REAL MEN do NOT play around with keyboards or send emails....
Real men are all out banging chix and smoking and drinking...
So unless you find a keyswitch that makes the ooo-s and ahhh-s that a women makes while wet, and at the end of the keystroke, the sound of a tree falling over coupled with murderous sounds of a chainsaw.... NO switch is manly..
Offline daerid
    • Rossipedia
« Reply #13 on: Fri, 15 February 2013, 01:34:02 »
Buckling Spring, hands down.
Offline Strelok
« Reply #14 on: Fri, 15 February 2013, 01:41:07 »
Dedicating your existence to satisfying women is not manly at all.
Dedicating your existence to making the loudest noise is amiable.
« Reply #15 on: Fri, 15 February 2013, 05:28:18 »
clearly you are so detached from manliness that you saw my statement from a vagina's perspective.
Men out getting p00n to please themselves.. that was my perspective..
You're obviously some whipped turkey with its head in the sand :D
Offline Krogenar
  • The Kontrarian
    • Buried Planet
« Reply #16 on: Fri, 15 February 2013, 08:12:21 »
Having experienced MX Greens (and since BS are ruled out) -- I would go with the Greens. They make a satisfying chunka-chunka ("gonna lay down some sheetrock") sort of sound. I can only imagine that Blues make a *tink*tink* ("Those shoes look FAB-YUH-LOUS!") sound, which is rather feminine. BS don't even enter into the discussion, because they're secure enough in their masculinity.
Quote from: Samuel Adams
Offline wolfofsin
« Reply #17 on: Fri, 15 February 2013, 09:18:41 »
It is understood Chuck Norris will never use a keycap name Cherry. For that manner Chuck Norris is beyond keycaps and touch typing for that manner. He thinks and it appears on screen.
« Reply #18 on: Fri, 15 February 2013, 09:27:48 »
I would have to hear the definition of this term, in relation to sound, before I named a switch, however:
As a 60-year-old husband and father, over 6' and 100 kilogram current active Tae Kwon Do black belt, I can wear a pink shirt and nobody will question my manhood for a nanosecond.
My keyboard of choice, with the sound and feel I consider most pleasing and appropriate, is a flossed, padded Model F. The perfect combination of all ergonomic factors, in my opinion. Its 8-1/4 pound (3.75 kg) weight is part of its character, along with its 195 square inch (a whopping 1/8 of a square meter!) footprint.
All Cherry switches sound like plastic to me, with blues and greens feeling best but sounding worst.
Alps are similar but better in sound, and may or may not feel great.
Pretty much everything else pretty much sounds like nothing.
- D Trump 2026-10-24
Offline uzoc
« Reply #19 on: Fri, 15 February 2013, 09:37:41 »
Yes, any of the "lasers". "space rim shot" is not bad, either. Sounds attached!
Offline daerid
    • Rossipedia
« Reply #20 on: Fri, 15 February 2013, 10:24:35 »
Lest we forget: tp is from Jersey
Offline BucklingSpring
« Reply #21 on: Fri, 15 February 2013, 20:59:57 »
what's a dark grey?
Boards I own, click ->
Offline Strelok
« Reply #22 on: Fri, 15 February 2013, 21:05:15 »
what's a dark grey?
It's like a heavy black, meant for space bars.
Offline ekw808
  • Ekw
« Reply #23 on: Fri, 15 February 2013, 21:41:59 »
Not everyone from jersey is an *******.
[One Keyboard at a time]
Offline Hak Foo
  • Make America Clicky Again!
« Reply #24 on: Fri, 15 February 2013, 23:19:53 »
Can't you just figure out what switches they use on Gurren Lagann?  Isn't that the default source of manliness?
Overton130, Box Pale Blues.
« Reply #25 on: Sat, 16 February 2013, 00:06:58 »
Am I mistaken in thinking white alps used to be called "strongman" switches?
Offline Michael
  • Formerly Bro Caps
« Reply #26 on: Sat, 16 February 2013, 01:42:40 »
The heavy 'thock' of 55g Topre's on a RealForce board have got to be the manliest sounding switches on earth.
 :cool:
Offline rootwyrm
  • The Hands of Steel
    • My Website!
« Reply #27 on: Sat, 16 February 2013, 02:23:10 »
You are not; the White Complicated was marketed as the "Strongman" due to it's 75cN(+-25cN) activation force.
However, the SMK is probably the absolute toughest sounding switch there is. It clicks with a deep authority, on activation and on return. However, listening to me type on just about anything has been described as the manliest thing ever. Just because it tends to resemble a minigun. Even if they aren't clicky switches. (Or especially because they aren't clicky. MX Blacks with shoddy ABS caps, looking at YOU.)
"I remain convinced I am the only person alive who has successfully worn out an IBM Model M mechanically."
Daily Drivers: Adesso 625 (NPKC PBT / Kailh Blue), Rosewill RK9000V2 (KC PBT / MX Brown), 1994 Model M13, Sun Type4, and the rare IBM 1394540.
« Reply #28 on: Sat, 16 February 2013, 06:06:53 »
I thought he was from New Jersey ...  :confused:
Offline Hyde
  • White Tofu Extraordinaire
« Reply #29 on: Sat, 16 February 2013, 07:18:33 »
They don't use switches they use drills  :P
Also to my understanding that the manliest switch that you can still buy and is not buckling spring would be the Clicky ALPS from Matias.
Offline quadibloc
  • Layout Fanatic
    • John Savard's Home Page
« Reply #30 on: Sat, 16 February 2013, 11:22:30 »
It's a pity that IBM doesn't manufacture beam spring keyboards for the IBM PC. Such a keyboard would have been the appropriate answer to this question.
Offline lazerpointer
  • ya gotta stay phresh
« Reply #31 on: Sat, 16 February 2013, 12:31:38 »
No buckling springs?  :-\ then it would have to be Cherry browns with soft .2mm o-rings
i type, therefore i geekhack
