Author Topic: What's Bothering You? (The thread about what is bothering you.)  (Read 7900027 times)
0 Members and 25 Guests are viewing this topic.
Offline xondat
  • i'm not a star
Re: What's Bothering You? (The thread about what is bothering you.)
« Reply #12400 on: Thu, 07 January 2016, 17:19:21 »
Friend said he'd 'just go get' something and it's been 6 hours :'( :'(
Offline DAVYtm
  • #dateless
« Reply #12401 on: Thu, 07 January 2016, 17:23:39 »
Gotta give a man a chance to eat a big burrito
« Reply #12402 on: Thu, 07 January 2016, 17:24:21 »
I think they screwed up on my brake job a few weeks ago I just drove my jeep today for the first time and I think one of my brakes is locked up.  :-\
Offline xondat
  • i'm not a star
« Reply #12403 on: Thu, 07 January 2016, 17:35:39 »
Just realized he went to work :( When he gets back I'll probably be asleep
Offline DAVYtm
  • #dateless
« Reply #12404 on: Thu, 07 January 2016, 18:34:48 »
The struggle. If you were in Buffalo I'd be down for some burritos!
« Reply #12405 on: Thu, 07 January 2016, 23:00:11 »
First UPS tracking says my ~40lb of dog food was delivered today but it wasn't.
Second I had to reinstall windows and its been updating forever....currently installing update 135 of 216.
And thirdly I can't do the cad work I picked up to make an extra couple bucks until the windows updates are done.
One more..apparently my mouse dongle won't work when I have a usb3 portable drive plugged in.... :-\
There's a severe memory leak in the Windows update tool.
I had a new installation installing around 200 updates.  It got to about 172, filled the RAM, filled the swap and basically hung for at least 12 hours (I left it overnight).  The next morning I tried to cancel the process, and ended up just powering down the machine.  Upon reboot it seemed to finish installing the updates it had processed, and offered a bunch more.  Another reboot.  A bunch more updates.  Another reboot.  A bunch more updates.  Another reboot.  Thank you Microsoft.
Yeah my windows update was using ~12 gigs of ram :eek:
You no got SSD ?
My windowz updates finish within 1 hour..
A strong Cpu helps lots too..
840pro
4.8ghz 2600k
16gb ddr 2600
It's sad to think this is probably approaching the minimum system requirements JUST TO INSTALL UPDATES on Windows.
Offline alienman82
« Reply #12406 on: Thu, 07 January 2016, 23:03:47 »
removed.
« Last Edit: Thu, 01 March 2018, 16:26:01 by alienman82 »
« Reply #12407 on: Thu, 07 January 2016, 23:55:48 »
You no got SSD ?
840pro
4.8ghz 2600k
16gb ddr 2600
Well,, the reason you'd need the CPU power, is because it does checksum for every update.. and I'm not super sure, but the whole ordeal is not multithreaded either.. so it's reliant on single core performance..
And with this sort of thing,  memory bandwidth, and disk bandwidth makes a big difference as well, because it's just moving things back and forth.
Offline Steezus
  • Keeper of Facts
« Reply #12408 on: Fri, 08 January 2016, 00:00:08 »
I wonder who I pissed off to get DDOS'd... somebody using a CloudFlare server.
« Reply #12409 on: Fri, 08 January 2016, 00:00:13 »
You no got SSD ?
840pro
4.8ghz 2600k
16gb ddr 2600
Checksums for a couple of hundred updates shouldn't take more than a couple of minutes, even on a humble CPU.
There was another bug in Windows update a few years back where for each update Windows would check each other update, whether it was installed or not.  And for each one of those updates it would check all the other updates, and so on.
Almost safer not to install any updates, and just unplug your network cable.
Offline Floody
  • Formerly Flood
  • But is it?
« Reply #12410 on: Fri, 08 January 2016, 05:54:45 »
Stupid Windows 10 update must have deleted my media player from my Windows 10 N copy. Spent an hour looking for it and trying to reinstall it.
Offline jerue
  • (Whenever that happens :P)
« Reply #12411 on: Fri, 08 January 2016, 07:44:28 »
Walmart wants $7.50 for a Digorno stuffed crust pizza. Almost 8 BUCKS!!! May as well order Pizza hut. Or wait for sales.
« Reply #12412 on: Fri, 08 January 2016, 08:05:16 »
Lol.. I wish they'd bring back 555 @ Dominos.
I used to have an Indian friend,  he became obese in 1 year ever since the introduction of the 555..
I myself must've eaten a hundred of pizzas that first year.
Offline whmeltonjr
« Reply #12413 on: Fri, 08 January 2016, 08:40:54 »
Holy crap that's ridiculous. They're like $5 here
« Reply #12414 on: Fri, 08 January 2016, 08:54:33 »
does dijourno come with enough cheese ?   I like Thick cheese-ness
Offline cseng
« Reply #12415 on: Fri, 08 January 2016, 09:16:54 »
Stress. I feel like dying.
Offline bcredbottle
« Reply #12416 on: Fri, 08 January 2016, 09:24:59 »
****ing with you man.
My recharging formula:
Exercise 45 minutes (whatever you can motivate yourself to do)
Cut down on caffeine a bit.
Sleep in one day (push things aside if you can, make it a priority).
Less sugar (less energy swings).
No TV or electronic anything more than two hours before bedtime.
Make it a religious priority and you'll feel better soon
Offline jerue
« Reply #12417 on: Fri, 08 January 2016, 09:36:28 »
They used to be about $6 not too long ago. Not sure what happened...but I should be doing better anyways
I am a sucker for the 50% off Online deals. Makes Pan Pizza worth it.
Not really. The stuffed crust is the only type of Digorno I'll buy as it's worth eating through all that cardboard for the delicious crust at the end   :))
Offline whmeltonjr
« Reply #12418 on: Fri, 08 January 2016, 09:41:04 »
I just realized you were taking about stuffed crust. Think they're around $6.50 or so, which is too much. I don't even by the normal ones at $5. Gotta wait for coupons or sales like you said.
Offline inanis
  • Truly Literally The Cloud
    • SEALWoodworking
« Reply #12419 on: Fri, 08 January 2016, 10:13:08 »
If you ever need to talk send me a PM. We've all been in a similar place. Perspective helps.
Offline baldgye
  • Will Smith Disciple
« Reply #12420 on: Fri, 08 January 2016, 11:16:42 »
I got something in the post today and it has made me switch out nearly all of Miami Twice set that was on my board... I think I need some help!!!
« Reply #12421 on: Fri, 08 January 2016, 11:17:47 »
Turns out not only did I need new pads and rotors but now I need calipers also. Anybody know where I can find a money tree?
Offline inanis
    • SEALWoodworking
« Reply #12422 on: Fri, 08 January 2016, 11:21:39 »
I've totally been there. I had a similar situation, one of the bolts that held my caliper on sheered right off. EVERYTHING had to get replaced. I was eating ramen form weeks. Of course those salty carbohydrates are yummy af, so at least I had that going for me.
Offline mr.squishy
  • I like beer and keebs
« Reply #12423 on: Fri, 08 January 2016, 11:24:59 »
mmmmm ramen
Offline iamtootallforthis
  • Something a lot Funnier
  • I like green stuffs.
    • WTB/WTTF Thread
« Reply #12424 on: Fri, 08 January 2016, 11:27:30 »
Pictures!
Offline baldgye
« Reply #12425 on: Fri, 08 January 2016, 11:29:47 »
Pictures!
in the media section but..
Offline xondat
  • i'm not a star
« Reply #12426 on: Fri, 08 January 2016, 11:30:34 »
Pictures!
Stormtrooper?
Offline baldgye
« Reply #12427 on: Fri, 08 January 2016, 11:32:27 »
Pictures!
Stormtrooper?
sì
Offline xondat
  • i'm not a star
« Reply #12428 on: Fri, 08 January 2016, 11:35:41 »
Pictures!
Stormtrooper?
sì
Whats bothering me - I didn't pick these up.
    • WTB/WTTF Thread
« Reply #12429 on: Fri, 08 January 2016, 11:41:13 »
Pictures!
Stormtrooper?
sì
They'll be up for sale on [CTRL]ALT after Bunny and Cody finish up with all the other sales.
Offline alienman82
« Reply #12430 on: Fri, 08 January 2016, 13:42:24 »
removed.
« Last Edit: Thu, 01 March 2018, 16:25:53 by alienman82 »
Offline dgreekstallion
  • B.S. Fiend
« Reply #12431 on: Fri, 08 January 2016, 14:23:34 »
Going to bed alone and lonely every night.
Recent keyboard fanatic.
Model F-122 convert.
Offline xondat
  • i'm not a star
« Reply #12432 on: Fri, 08 January 2016, 14:23:55 »
Custom cases are expensive.
Offline inanis
    • SEALWoodworking
« Reply #12433 on: Fri, 08 January 2016, 14:27:46 »
It helps zero ****ing percent, but everyone has been there, man. Be kind and things will swing your way again. :)
I have to work late tonight. And with people I have very little confidence in. I am getting a headache just thinking about it.
Offline beehatch
  • baehatch
« Reply #12434 on: Fri, 08 January 2016, 14:30:22 »
jaw hurts from too many quesadillas
Offline dgneo
  • Supervillain
« Reply #12435 on: Fri, 08 January 2016, 14:31:38 »
My coworker is attempting to teach me how to use our deployment system. I'd rather watch paint dry.
Offline ANightOnCloudNine
« Reply #12436 on: Fri, 08 January 2016, 14:31:51 »
jealous
Offline ghostjuggernaut
« Reply #12437 on: Fri, 08 January 2016, 14:49:29 »
Multimeter probe snapped
Get some fluke leads. They can break, but I have only had one break on me in about 10 years. And it was badly bent before it broke.
Offline alienman82
« Reply #12438 on: Fri, 08 January 2016, 14:51:13 »
removed.
« Last Edit: Thu, 01 March 2018, 16:25:48 by alienman82 »
« Reply #12439 on: Fri, 08 January 2016, 14:57:49 »
I'm in Jwaz's bed but he's not here :(
Offline Jema
  • CHIPOTLE WHERE
  • You make my words I'm gonna get my grade 10
« Reply #12440 on: Fri, 08 January 2016, 17:53:22 »
California smog requirements can suck it big time  :'(
Offline FreeCopy
« Reply #12441 on: Fri, 08 January 2016, 18:04:12 »
That what you and demik are calling it?
Keyboards
Poker II | Leopold fc500r | Bolt Modded M 1391401 x2 08NOV90 - 19NOV90 | FK-2001 White Alps Clones | Filco MJ2 104 |  Bolt Modded SSK 1391472 27JUL87 | Winkeyless B.87 TKL | MiniVan GateReds 62g
« Reply #12442 on: Fri, 08 January 2016, 18:07:23 »
Hahahahhhahahaha.. hah ahahhaah...  ah hahha.. ah ha.. .. hoooowehhhh... ahhhhh.. oh god... the tears won't stop...
But in all seriousness, i think many young guyz/girlz  has this problem..  They want to marry up/ date - up..
I find that if most people would just ' date down ' there would be infinitly more potential partners..
Overall,  I think even if you are a 'very objective' person, you think, well I want at least 1:1..    I still think that this only ruins dating for you because you reduce greatly the opportunity for you to gain 'experience' ..
It's like for your first car,  you don't need the best one,  you don't want that ridiculously high monthly payment, etc..
Just lease a cheaper car .  drive it around,  see how you like it..     Then when you're ready,  hey, maybe you buy it straight up,  OR you can decide, no I want a better car...
But if you're always waiting for the mercedes, even if you find a way to afford it later on,  you may not have the 'experience' to utilize it properly / maintence/ etc..
So.. Go out today,  and find a car, start driving, is the important take away from all this.
Offline SploogeFactory
  • Vitamin D deficient
« Reply #12443 on: Fri, 08 January 2016, 19:25:00 »
TL:DR any hole's a goal.
Methylated Spirits, not even once.
  • Live long and prosper
« Reply #12444 on: Fri, 08 January 2016, 19:26:36 »
omg tp has wisdom :eek: :llama:
tp thread is tp thread
Offline alienman82
« Reply #12445 on: Fri, 08 January 2016, 19:27:12 »
removed.
« Last Edit: Thu, 01 March 2018, 16:25:30 by alienman82 »
« Reply #12446 on: Fri, 08 January 2016, 19:36:11 »
i'm just an observer of the normal distribution s'all
« Reply #12447 on: Fri, 08 January 2016, 19:48:48 »
Tldr, now married to a ****ty car
Offline inanis
    • SEALWoodworking
« Reply #12448 on: Fri, 08 January 2016, 21:41:45 »
I had to work late tonight, I thought that was going to be a whole thing. Turns out it went smooth as silk. I should be happy. Instead, I'm just bored. I dunno what is wrong with me.
To compensate I ate the remainder of my homemade ice cream, which has set me off into a coughing fit (cold triggers the cough). So that was probably not the best plan, but it was so good. Thank goodness no one is here to hear me coughing like a fool.
Offline Air tree
  • Better late than never ^-^
  • Formerly not demik
« Reply #12449 on: Fri, 08 January 2016, 23:00:55 »
Me being behind in highschool math sucks ****. Well time to play catch up and work my ass off.
