Author Topic: What's Bothering You? (The thread about what is bothering you.)  (Read 7867137 times)
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
Re: What's Bothering You? (The thread about what is bothering you.)
« Reply #17150 on: Sat, 26 March 2016, 22:54:04 »
I found a weavel in my cereal bruh. ****in' weevils. I have to find the weevil source tomorrow.  :'( RIP Honey Bunches Of Oats
Offline whmeltonjr
« Reply #17151 on: Sat, 26 March 2016, 23:58:18 »
i think i dun gooooooooooof'd
bee pregnant?
Offline alienman82
« Reply #17152 on: Sat, 26 March 2016, 23:59:01 »
removed.
« Last Edit: Thu, 01 March 2018, 15:42:34 by alienman82 »
Offline bocahgundul
  • a seal
« Reply #17153 on: Sun, 27 March 2016, 00:00:01 »
PLS GOD I'M NOT A SEAL
Offline alienman82
« Reply #17154 on: Sun, 27 March 2016, 00:01:08 »
removed.
« Last Edit: Thu, 01 March 2018, 15:42:31 by alienman82 »
Offline alienman82
« Reply #17155 on: Sun, 27 March 2016, 00:01:39 »
removed.
« Last Edit: Thu, 01 March 2018, 15:42:28 by alienman82 »
Offline bocahgundul
  • a seal
« Reply #17156 on: Sun, 27 March 2016, 00:04:39 »
andre the seal!
NO I'M NOT ANDRE THE SEAL
ITS JUST ANDRE
Offline alienman82
« Reply #17157 on: Sun, 27 March 2016, 00:08:12 »
removed.
« Last Edit: Thu, 01 March 2018, 15:42:25 by alienman82 »
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
« Reply #17159 on: Sun, 27 March 2016, 00:48:18 »
I'm about to have to turn in my, 'computer guy' card.... I've never had this much trouble upgrading a hard drive.... maybe buying these cheap ssd's was a bad idea.
« Reply #17160 on: Sun, 27 March 2016, 00:50:19 »
what's the trouble..
Computer guy Tp4 is here to help..
« Reply #17161 on: Sun, 27 March 2016, 00:57:10 »
I clone the old ssd to the new larger ssd and it won't boot....two different PC's (dell laptops, one windows 10 the other 7 but probably upgrading once I get it to boot) even using different cloning methods neither one boot.
Tried all the tips and tricks I could find using Google.
Finally after spending the last couple days messing with this I broke down and spent almost as much on some software to do it for me as I paid for the SSD's, it's currently migrating, hopefully it works.
« Reply #17162 on: Sun, 27 March 2016, 00:58:43 »
dah...
Are you using the macrium reflect ?  it's worked really well for me, and it's straightforward..
« Reply #17163 on: Sun, 27 March 2016, 00:59:38 »
bee pregnant?
the last thing the world needs is that OnO
« Reply #17164 on: Sun, 27 March 2016, 01:00:27 »
bee pregnant?
Hrrrmm.. I'm visualizing it now..   I think the kid would be pretty cute..  Go for it demik.. !!
« Reply #17165 on: Sun, 27 March 2016, 01:02:17 »
dah...
That's what I tried first. :(
« Reply #17166 on: Sun, 27 March 2016, 01:05:12 »
dah...
Where did you get stuck.
« Reply #17167 on: Sun, 27 March 2016, 01:11:30 »
dah...
After cloning, it just won't boot. Try repairing with macrium, then manually with command line and boot disk things like MBR and BCD and keep getting different errors and/or commands throw errors in the process, like trying to rebuild BCD and it says can't find the drive etc.
Offline Air tree
  • Better late than never ^-^
  • Formerly not demik
« Reply #17168 on: Sun, 27 March 2016, 01:14:02 »
Feeling down right now...
I feel like I need a hug.  :(
« Reply #17169 on: Sun, 27 March 2016, 01:14:06 »
Are you putting the cloned drive back into the same computer? or a different computer.
Offline smknjoe
« Reply #17171 on: Sun, 27 March 2016, 01:15:10 »
HDclone -https://www.miray.de/products/sat.hdclone.html
Clonezilla -http://clonezilla.org/
dd & ddrescue can be helpful too.
Boot from a live USB like UBCD and it will have all of the tools you need. If that doesn't do it then...
SSKs for everyone!
« Reply #17172 on: Sun, 27 March 2016, 01:19:00 »
Same computer, I'm not a total noob. :P
I tried clonezilla after macrium didn't work, that was on the second system and it wouldn't even try to boot.
« Reply #17173 on: Sun, 27 March 2016, 01:23:33 »
Ok, so ur cloning the drive... Then booting from it right?
Have you tried,  Imaging the drive..   REMOVE IT, replace that slot with an EMPTY SSD,  Boot from the Macrium bootable flash drive..
Restore from the image file..
Offline smknjoe
« Reply #17174 on: Sun, 27 March 2016, 01:26:00 »
It's been a while since I've done it, but...
You used to have to plug the new "target" drive into the "source" system to make sure the drivers were installed (the "target" drive was recognized by the OS that you are "cloning") before starting the cloning process. Otherwise, you would run the risk of the "target" drive not being recognized after completion.
« Last Edit: Sun, 27 March 2016, 01:28:29 by smknjoe »
SSKs for everyone!
« Reply #17175 on: Sun, 27 March 2016, 01:35:41 »
Tried restoring a macrium image and a Windows backup image those wouldn't work either.
Yes cloning from CD/USB bootable media then removing original drive.
The drive seems to be automatically recognized at least in Windows 10.
« Last Edit: Sun, 27 March 2016, 01:39:34 by SpAmRaY »
Offline smknjoe
« Reply #17176 on: Sun, 27 March 2016, 01:41:04 »
Oh, Win10. Win10 bootloader could be a problem and UEFI Secure Boot could be causing issues as well. Set your BIOS bootloader to "legacy" or turn off Secure Boot and see if that works.
SSKs for everyone!
« Reply #17177 on: Sun, 27 March 2016, 02:53:00 »
« Reply #17178 on: Sun, 27 March 2016, 09:50:20 »
I'm hungry and everything's closed
Offline mason
  • have fun with her, ryan
« Reply #17179 on: Sun, 27 March 2016, 10:12:07 »
It was 80° last week
now it's snowing
Offline Kompanion
« Reply #17180 on: Sun, 27 March 2016, 10:21:20 »
I have company coming over tomorrow and I need to clean my house. But I'm lazy.
________________________________________________
Offline beehatch
  • baehatch
« Reply #17181 on: Sun, 27 March 2016, 10:39:32 »
the least of your problems OnO
Offline joey
« Reply #17182 on: Sun, 27 March 2016, 10:42:44 »
Feel like I'm getting unwell.
Offline katushkin
  • Too Keycool for School
  • Just the guy
« Reply #17183 on: Sun, 27 March 2016, 10:54:24 »
This is literally the only reason I clean the house. I get too comfy with all my stuff around me in convenient places and it's not until I am meant to have someone round...
« Reply #17184 on: Sun, 27 March 2016, 11:09:46 »
I only clean whenever I get new stuff.
It has been a month since I got something new.
Help me :(
Offline Waateva
« Reply #17185 on: Sun, 27 March 2016, 11:21:13 »
Help me :(
What happened to the constant stream of vinyl?
Offline Kompanion
« Reply #17186 on: Sun, 27 March 2016, 11:23:06 »
Help me :(
What kind of new? Like new furniture?
Offline Kompanion
« Reply #17187 on: Sun, 27 March 2016, 11:24:30 »
Yea clutter has never bothered me. I like organized chaos. But then my mom always has something to say about it... so I'd rather just clean up.
But this company is someone I'm actually trying to impress soo.. definitely clean
Offline beehatch
  • baehatch
« Reply #17188 on: Sun, 27 March 2016, 11:27:14 »
stop it
« Reply #17189 on: Sun, 27 March 2016, 11:27:28 »
Help me :(
Anything. Lately it's my records. I'll store them neatly then look at the mess around it and see that I need to pick up. For a couple weeks there my **** was spotless. But I had to take a break from buying **** to pay some stuff off and it's now a mess :(
Offline Kompanion
« Reply #17190 on: Sun, 27 March 2016, 11:30:51 »
haha that's a strange routine to get in to. I would have no problem though, because I have a problem buying new things...  :/
Help me :(
Offline katushkin
  • Just the guy
« Reply #17191 on: Sun, 27 March 2016, 11:32:38 »
OuO
« Reply #17192 on: Sun, 27 March 2016, 11:33:55 »
I mean it's bad because I'm spending money on **** I really don't need but uh... it's helping me not be a dirty **** so... yay?
I'm almost done paying off a card so I'll be getting some new **** soon OuO
Offline beehatch
  • baehatch
« Reply #17193 on: Sun, 27 March 2016, 11:36:49 »
we'll see how that goes
« Reply #17194 on: Sun, 27 March 2016, 11:38:44 »
What does that mean
Offline Kompanion
« Reply #17195 on: Sun, 27 March 2016, 11:38:48 »
you never actually pay off your cards. You just get sorta close
Offline Kompanion
« Reply #17196 on: Sun, 27 March 2016, 11:39:34 »
OuO
60+ year old lady who decides if I get an adopted dog or not  :thumb:
Offline katushkin
  • Just the guy
« Reply #17197 on: Sun, 27 March 2016, 11:40:12 »
I've had about £2500 on my credit card for about two years l0l
OuO
Oooo doggy!
Offline beehatch
  • baehatch
« Reply #17198 on: Sun, 27 March 2016, 11:40:49 »
What does that mean
guess
« Reply #17199 on: Sun, 27 March 2016, 11:41:48 »
And they know it.
I had a CC that had a limit of 1.5k. I was 200 away from paying it off and closing the account. Literally the next day I get a credit bump of 2k. Guess what CC I'm currently paying off now? OnO
OuO
Good luck, those 60 year old ladies are the worst to impress. What dog are you looking to adopt?
