Author Topic: In Tokyo at the moment; Should I get a HHKB Pro 2 or HHKB Pro JP?  (Read 7611 times)
Offline nmur
  • ಠ_ಠ
The prices for both of these keyboards are much lower here ($250AUD) than what it would be to buy and import to Australia ($350+), so it'd be a great opportunity.
I know the choice between the two boards is largely preference, but the way I see it, the JP version has dedicated arrow keys, which are great, but has a JIS layout which will go unused and will also give me dead keys (but can be recapped) and a layout which is not keycap set friendly. However, the JP version does have that cool exclusivity to it...
So currently leaning towards the regular Pro 2. Any other reasons I should be considering for my choice?
Offline ApocalypseMaow
  • Kitteh Overlord
  • Say WHAAT...
Re: In Tokyo at the moment; Should I get a HHKB Pro 2 or HHKB Pro JP?
« Reply #1 on: Sat, 16 May 2015, 05:32:11 »
Pro 2
Offline Belfong
« Reply #2 on: Sat, 16 May 2015, 05:44:40 »
Probably you have to try typing on it to see if you can get used to the shorter space bar. If you can, then those dedicated arrow keys will be useful. But I’d still go with Pro 2 as the standard used by many WW.
Offline absyrd
  • CPT HYPE PADAWAN
« Reply #3 on: Sat, 16 May 2015, 06:20:01 »
Forget the "exlusivity". That is just silly. And dedicated arrow keys aren't necessary. You get used to the fn layer ones on the pro 2 in no time.
Offline nmur
  • ಠ_ಠ
« Reply #4 on: Sat, 16 May 2015, 07:00:39 »
Probably you have to try typing on it to see if you can get used to the shorter space bar. If you can, then those dedicated arrow keys will be useful. But I�d still go with Pro 2 as the standard used by many WW.
I tried it out in a store earlier and found that the short space was just on the threshold of where my right thumb rests, which should be fine (I might miss it slightly from time to time).
I've used a HHKB Pro 2 for a week at work (programming) and found that doing key combinations like ctrl + shift + fn + arrow keys required a moment of thought before being carried out successfully. I'm sure that after a more extended period, I would get used to it.
Offline KeypressGraphics
  • Dare to Dream
    • Keypress Graphics
« Reply #5 on: Sat, 16 May 2015, 07:28:59 »
I suggest the Pro 2. It'll have better re-sale value if you decide to flip it.
The Fn arrow key combination took me awhile to get used to but now that I've acclimatized its only slightly less convenient than dedicated arrow keys.
May all your key presses strike true.
  Choc Mini         HHKB
Offline tkim
« Reply #6 on: Sat, 16 May 2015, 09:03:55 »
Get the Pro 2, I use the keyboard heavily with excel and I found learning the new layout was quite easy.
Offline yuktsi
  • Colour my life with the chaos of trouble
« Reply #7 on: Sat, 16 May 2015, 09:09:03 »
get pro2.
with the release of topre mx stem in near future, you will have more choices for keycaps
email: yuktsi@ttggrr.cc
My collection
Poker 2 | LZ CE | Leopold FC700R | KMAC 1.2 | EXE | GON NS87 | GON Nerd TKL | Duck Poker | Duck Orion | Realforce 87u 55g | OTD 456GT | LZ B7 | OTD 360C | Ducky G2 Pro | Apple Extended | Apple M0116 | Apple M0116 | Cherry G80-1220HAD | Duck Octagon | HHKB Pro 2 | Duck Unicorn | LZ B8 | LZ RE | ENVKX | OTD 456GT | LZ FE | HHKB Type S | TX1800| Duck Orion V2 | LZ FE | KPad | KMAC Happy | ENVKX | LZ RV | KMAC 2 | Whale | Dolphin | EM7 | TGR Jane | VE.A | DK Saver | Matrix 10xv1.0 | Whale | HHKB BT | Dolphin v2 | EM7 v2 | SSK | SSK (Blue Label) | LZ SQ | Duck Octagon v2 | TX84 | GON Mobik | TX-CP | LZ Ergo2 | KMAC Happy HHKB | TGR 910 | TGR Tris | Matrix 8xv1.2 | KMAC Mini | Mira | Fjell | 356mini | Dolphin GH | EM7 GH | TARO EXENT | Masterkey Pro L Crysta l OTD Koala | Duck Viper | Keycult no.1 | 356mini | 356pad | Matrix 8xv2.0 | 420cl | Matrix 8xv1.0 | Whale Special | Poly Dolphin | Keycult No.2 | FMJ80 | Singa R2 | Whale Poly | 356cl | HBCP | Dolinger | Linger | FMJ80 | KFE
Offline nmur
  • ಠ_ಠ
« Reply #8 on: Sat, 16 May 2015, 09:38:15 »
get pro2.
That's a very good point, I forgot about that one.
Thanks everyone, I will go to pick one up tomorrow.  :thumb:
Offline yuktsi
« Reply #9 on: Sat, 16 May 2015, 09:42:43 »
since you are in Japan, pick up some extra topre keycap/keyset too
it's much cheaper in Japan iinm
My collection
Offline absyrd
  • CPT HYPE PADAWAN
« Reply #10 on: Sat, 16 May 2015, 09:51:06 »
get pro2.
You won't regret it. Post pics and feedback once you've played with it for a few days!
Offline nmur
  • ಠ_ಠ
« Reply #11 on: Sat, 16 May 2015, 10:30:09 »
Do you know where I can get topre keycaps? I've only been to Yodobashi in Akihabara, but they had a pretty poor selection of keycaps (all Cherry MX too).
Offline rsadek
  • raging keyboard monkey
« Reply #12 on: Sat, 16 May 2015, 10:42:19 »
Both?  :D
The JP is interesting bc of the possibility of adding extra modifiers and function keys. Using Hasu's controller (easy to install) you can program it however you like!
Dedicated keys are not necessary, it's true. However with heavy use at the beginning I experienced some strain in the wrist/pinky. Switching between boards a couple times in the day helps which I get used to the new motion.
You can always sell the other one easily!
-R
❤️Keeboardz
Offline IonutZ
  • Stay awhile and listen
    • SC
« Reply #13 on: Sat, 16 May 2015, 11:36:48 »
* HHKB Pro 2 Type-S, a Realforce 87U Type-S variable, and a Realforce 87U 55g.
* Swap out the 55g in the variable.
* Sell the new Realforce 87U Variable.
* Live long and prosper.
Offline septamber
« Reply #14 on: Sat, 16 May 2015, 11:39:56 »
RIP wallet  ^-^
Offline IonutZ
    • SC
« Reply #15 on: Sat, 16 May 2015, 11:42:01 »
RIP wallet  ^-^
Basically. lol
That's what's in the mail right now from EMS :D (- the HHKB part, did that 2 weeks ago hahah)
Offline GL1TCH3D
« Reply #16 on: Sat, 16 May 2015, 11:42:57 »
The JP layout is not the same in terms of feeling. Part of what makes the HHKB pro 2 so good is that fantastic layout.
« Reply #17 on: Sat, 16 May 2015, 13:17:44 »
Pick the layout you'd like. Not rocket surgery.
Offline IonutZ
    • SC
« Reply #18 on: Sat, 16 May 2015, 13:43:52 »
Make sure to invert bottom row keycaps!
Offline trizkut
« Reply #19 on: Sat, 16 May 2015, 13:45:32 »
No.
Offline jonathanyu
« Reply #21 on: Sat, 16 May 2015, 13:51:30 »
Pro jp.  JIS layout is so much better
Offline septamber
« Reply #22 on: Sat, 16 May 2015, 13:52:15 »
Invert all the keys for maximum cool  :cool:
Offline jonathanyu
Offline rsadek
« Reply #26 on: Sun, 17 May 2015, 00:36:11 »
Also one JP type S for rsadek who will promptly repay you and be eternally grateful
❤️Keeboardz
Offline Nai_Calus
  • CLACK
- IBM 4704 Model F 107-key "Bertha"
Other boards: Kinesis Essential, Infinity(G.Clears), Ergodox(MX Blues), Monoprice 9433
Eternally searching for Celestial Blue BS V2 and blue/purple Bros.
Offline a_ak57
« Reply #28 on: Sun, 17 May 2015, 13:13:04 »
What's this now?  Forgive me, I don't really hang around much and haven't heard about this.
Offline absyrd
  • CPT HYPE PADAWAN
« Reply #29 on: Sun, 17 May 2015, 13:23:06 »
Apparently CTRLALT and JTKeycaps are making moves to have these ready to go soon:
https://geekhack.org/index.php?topic=70659.0
https://geekhack.org/index.php?topic=71630.0
« Reply #30 on: Sun, 17 May 2015, 13:30:12 »
Don't fall for that blasphemy. Topre on topre ****rry on ****rry. The way keyboard gods intended it to be.
« Reply #31 on: Sun, 17 May 2015, 15:42:31 »
True dat, double true. Topre caps is best caps.
Offline Sencha
  • HHKB Pro
  • MX Reds <3
« Reply #32 on: Mon, 18 May 2015, 02:32:27 »
I'd probably go with the JIS purely as the HHKB space bar feels like crap on the 6-7 models I've used.
Offline nmur
  • ಠ_ಠ
« Reply #33 on: Mon, 18 May 2015, 07:35:40 »
Picked up the Pro 2 (white with blanks) today  :thumb:
didn't have to pay the 8% tax on it so it came to like 22400 yen ($187 USD) which is pretty damn good. I think I'll wait until I get home in a week or so to unbox it though (if I last that long).
Sofmap had a couple of Leopold FC660C's to type on which were also pretty nice!
Offline absyrd
  • CPT HYPE PADAWAN
« Reply #34 on: Mon, 18 May 2015, 07:43:57 »
Great price. You won't last the week. You won't be disappointed.
Offline hwood34
  • underwater squad
  • #1 CL stan
    • Keyboard Illuminati
« Reply #35 on: Mon, 18 May 2015, 09:39:00 »
neither
Offline a_ak57
« Reply #36 on: Mon, 18 May 2015, 10:05:28 »
Neat, though it looks like you can only get them via buying a keycap set.  Oh well, I like stock topre keycaps enough anyway.
Offline TopreFan333
« Reply #37 on: Mon, 18 May 2015, 11:15:52 »
HHKB is for n00bers
tp4tissue's day:
- wakes up
- runs search for "HHKB"
- craps on any necessary threads
- take a break
- [repeat]
Offline absyrd
  • CPT HYPE PADAWAN
« Reply #38 on: Mon, 18 May 2015, 11:18:59 »
They said somewhere in there they will be offering the stems alone. My HHKB and RF all have stock caps except for these new Bro Cap textured sets, and I personally won't be doing any slider replacement or MX keysets on them.
Offline nmur
  • ಠ_ಠ
« Reply #39 on: Tue, 19 May 2015, 08:56:01 »
I gave in. Using it on my laptop in my hotel bed.
Offline absyrd
  • CPT HYPE PADAWAN
« Reply #40 on: Wed, 20 May 2015, 03:00:56 »
Told ya so! How does the feels feel?
Offline kaminbobby
  • -_^
« Reply #41 on: Wed, 20 May 2015, 22:58:39 »
Have both i like the JP one better
-_^
