Author Topic: Gift from dad  (Read 3162 times)
Offline derzemel
Gift from dad
« on: Sat, 23 May 2015, 04:58:17 »
My dad lives in Italy and I have been telling him about my new found passion. A few days ago I got a box from him with some stuff:
 :D ;D :D ;D :D ;D :D ;D :D
The ISO WYSEs are cherry MX Black... SMOOTH black... Vintage black  ;D ;D ;D
I now have some of switches for a TKL Project I am working on
The IBM, sadly is a rubber dome, but in a normal Model M case. I plan to open it to see if there are usable parts.
I cleaned the Gray WYSE and I am planning to use Soarer's Converter on it. I hope it works with ISO. If it works, then I'll keep it as is and I'll find some vintage Blacks somewhere else
I am still not convinced that I should put in the effort to retrobright the yellowed one. I also has some very shiny caps.
Also, the yellowed had an EM shield inside it which I cleaned and moved to the gray one:
Here are some pictures with the cleaned gray one:
Offline absyrd
  • CPT HYPE PADAWAN
Re: Gift from dad
« Reply #1 on: Sat, 23 May 2015, 05:36:00 »
Daddy coming through! How did he know what was good to send and not to just ship you a ton of rubber domes???
Offline henz
  • What?
Re: Gift from dad
« Reply #2 on: Sat, 23 May 2015, 05:55:32 »
real men knows what mechanical means :)
Offline katushkin
  • Too Keycool for School
  • Just the guy
Re: Gift from dad
« Reply #3 on: Sat, 23 May 2015, 06:19:07 »
That WYSE board looks really nice and clean. Great find from dad!
Offline derzemel
Re: Gift from dad
« Reply #4 on: Sat, 23 May 2015, 07:31:02 »
Well, we talked a bit and I explained what Cherry MX is and how Model Ms look. I then showed him a WYSE pc that was for sale on Kijiji.it and now i have these :D
Re: Gift from dad
« Reply #5 on: Sat, 23 May 2015, 08:52:46 »
That's a great present
Offline vivalarevolución
Re: Gift from dad
« Reply #6 on: Sat, 23 May 2015, 11:16:53 »
You can convert that rubber dome Model M into a buckling spring, if you want.  Just get some springs and regular Model M keycaps that can house the springs (the rubber dome keycaps cannot), and you are good to go.  I've done it before.
Offline Snowdog993
  • Grace Under Pressure
  • Justifiably Clueless.
Re: Gift from dad
« Reply #8 on: Sat, 23 May 2015, 11:30:03 »
That's a pretty good idea.  One idea I was thinking was just throwing a terminal internals into the chassis.  Hook up the ribbons, done! That would work too.
Offline derzemel
Re: Gift from dad
« Reply #9 on: Sat, 23 May 2015, 13:34:04 »
Yes, I was thinking too to source some Model M Keycaps + springs with flippers and throw away the rubber domes
W530...   Laptop of the Pr0zz
Yes, that thing is a beast and I love it, but it also weighs almost 3kg + 1 kg the charger
Offline Blaise170
  • ALPS キーボード
    • XYZ
Re: Gift from dad
« Reply #10 on: Sat, 23 May 2015, 17:37:42 »
I'm more interested in the bottle.  ;)
Offline hwood34
  • underwater squad
  • #1 CL stan
    • Keyboard Illuminati
Re: Gift from dad
« Reply #11 on: Sat, 23 May 2015, 22:43:06 »
awesome your dad actually knew what to pick up :))
Re: Gift from dad
« Reply #12 on: Sat, 23 May 2015, 23:30:49 »
I've got some springs and flippers, if you want them.  I am not sure how many exactly, but it might be enough for a Model M.  Send me a PM if you are interested.
