Author Topic: Keycap, by Tp4, (heedpantsnow said original title too much suggestive)  (Read 7223 times)
Yea, I know, it's ironic that I was recently stabbed..
This keycap is for the Anime Fans..
Probably, the most Dangerous Keycap made to date..
118890-0
Aluminum (cap), Aircraft wood + Acrylic (display case)
Been making some caps for fun while learning to machine..
I made this one completely Solo.
This build process utilizes:
cnc Lathe (turned at 2000 rpm)
cnc Laser (used to cut display case)
cnc EDM (electrical discharge machining)
Software used:
Solidworks 2015
Mastercam 9
If any of ya'll anime fans are interested.. well... some bad news....
I discussed it with the local shop again today,  they changed their minds since the last time they gave me a quote, and won't do anything under 100.. so pretty much not gonna happen.
The issue is, I don't have that much time to machine it on my own.. at most i can produce around 20..
Offline logomachy
Re: The Maximum Pointy, by Tp4
« Reply #1 on: Thu, 03 December 2015, 01:11:32 »
I'll take 84.
« Reply #2 on: Thu, 03 December 2015, 01:17:31 »
I'll take 84.
Thanks for the support..  You hurd um' guys..  we just need to order 16 m0ar..
« Reply #3 on: Thu, 03 December 2015, 02:23:22 »
We're gonna need a bigger drill.
Offline nmur
  • ಠ_ಠ
« Reply #4 on: Thu, 03 December 2015, 02:25:59 »
we can do 100!
believe in the geekhack that believes in you!
Offline Jokrik
« Reply #5 on: Thu, 03 December 2015, 02:27:45 »
Offline KatzenKinder
« Reply #6 on: Thu, 03 December 2015, 02:29:55 »
YEY TPCAP
Offline logomachy
« Reply #7 on: Thu, 03 December 2015, 03:33:29 »
we can do 100!
We got this
Offline drewba
« Reply #9 on: Thu, 03 December 2015, 15:40:03 »
Is this what you were referencing in IRC? Where are the pokemon keycaps?
Offline mobbo
  • u fk
« Reply #10 on: Thu, 03 December 2015, 15:43:35 »
tp right now
Quote from: Binge
Offline absyrd
  • CPT HYPE PADAWAN
« Reply #11 on: Thu, 03 December 2015, 15:52:59 »
At first I assumed you built a drill like moleman so you can hide underground away from people.
Offline heedpantsnow
  • Old enough to know better
« Reply #12 on: Thu, 03 December 2015, 17:11:50 »
I came into this thread a little worried about what part of Tp I would see.
That keycap is cool!
I'm back.
« Reply #13 on: Thu, 03 December 2015, 17:26:06 »
« Reply #14 on: Thu, 03 December 2015, 19:40:51 »
This is exactly what I was going for..
You'd have to getz a whole 87x set though..
« Reply #15 on: Thu, 03 December 2015, 19:43:55 »
How did you know I waz a member of the mole people..
Re: Keycap, by Tp4, (heedspantsnow said original title too much suggestive)
« Reply #16 on: Thu, 03 December 2015, 20:30:51 »
OK, title changed.
Offline Hexterdude
  • I have a problem when it come to artisans
Re: Keycap, by Tp4, (heedpantsnow said original title too much suggestive)
« Reply #17 on: Thu, 03 December 2015, 20:32:01 »
Believe in the me that believes in the you
Offline inanis
  • Truly Literally The Cloud
    • SEALWoodworking
« Reply #18 on: Thu, 03 December 2015, 20:36:10 »
OK, title changed.
Your insecurity about the sexytimes is my favorite thing about you. Just so you know.
Also, keycap is cool. I don't know anything about anime, but I appreciate it nonetheless.
« Reply #19 on: Thu, 03 December 2015, 21:01:33 »
OK, title changed.
And your reference to sexytimes is one thing I really like about you inanis :)
I'm back.
« Reply #20 on: Thu, 03 December 2015, 21:04:04 »
OK, title changed.
I didn't think you would actually change the title!  :-X
Did you stop drinking and smoking yet?  I really don't want you to die bro.  :(
I'm back.
« Reply #21 on: Thu, 03 December 2015, 21:10:02 »
OK, title changed.
alas drinking is an occupational hazard in this country.. you just have to take it..
Making keycaps has been my only salvation..  because I certainly wouldn't be drunk around a Cnc Lathe that can easily take my arm off..
3000 rpm ftw..
« Reply #22 on: Thu, 03 December 2015, 21:10:43 »
OK, title changed.
I'm perfectly ok with the ACT-of..  but it's difficult for me to talks about it. specially on GH, since we're trying to keep it PG for the younger audience.
Offline clacktalk
  • circa 2015
« Reply #23 on: Thu, 03 December 2015, 21:17:02 »
only want if product pierces heavens
diary of a clacktalk
radio_killah: too much frank
« Reply #24 on: Thu, 03 December 2015, 21:19:41 »
Funny you should mention that..
We fired one out of a CO2 gun that just happens to be the exact diameter of the cap 18mm (cherrymx)
we shot it straight up on a grass field hoping it would come down,  Never found it.
 So, theoretically..  It pierced the heavens, and/or someone's car..
But we're sure no one died,  cuz we checked the local news for 2 days.
Offline nmur
  • ಠ_ಠ
« Reply #25 on: Thu, 03 December 2015, 21:53:12 »
hahaha
I wonder if the spiral groove actually made it rotate as it flew through the air
Offline GL1TCH3D
« Reply #26 on: Thu, 03 December 2015, 21:54:22 »
tp4 hates gl1tch3d for liking anime
tp4 makes anime keycap
« Reply #27 on: Fri, 04 December 2015, 05:40:22 »
Hahaha..
Glitch.. I'm sorriz if I've said something in those terms.. Surely I didn't mean it, since I myself watch anime..
Overall.. Keycap making has been a profound experience..
It's one thing to just buy a keyboard wth caps on them..  But TO MAKE..
I feel closer to my ergodox,  even though it's now significantly more dangerous to use the -F4- key.. which is where I've put one of these dorills.
To anyone else out there, who is considering making keycaps, give it a go,  it's fun, and really brings you closer to all the keyboards you own..
You don't need Fancy machines.....  I think I would've been just as happy making a plastic cap with a mold kit..
Offline GL1TCH3D
« Reply #28 on: Fri, 04 December 2015, 12:37:14 »
Hahaha..
Putting it on F4 just guarantees you that you won't rage alt+f4 out of a game
Offline bcredbottle
« Reply #29 on: Fri, 04 December 2015, 12:44:48 »
Software used:
Solidworks 2015
Mastercam 9
Do you have a pic of the stem?
« Reply #30 on: Fri, 04 December 2015, 15:46:35 »
Software used:
Solidworks 2015
Mastercam 9
it's a cross cut, using the EDM machine.. I didn't take a pic of it, since it doesn't seem that interesting, lol.
You can't machine the corners like poured plastics. there are no bits that can make the corner..  Even with a laser, it'd be hard to get a smooth wall.
I could also make it on the cnc mill instead of edm, still under consideration.
I tried the "square cross" like the holyops, I didn't like it because I feel like these pegs need as muc structural support as possible.
