Author Topic: cheap 60% DIY kits?  (Read 4353 times)
Offline AugustCanaille
cheap 60% DIY kits?
« on: Tue, 24 July 2018, 20:07:17 »
I'm trying to find a cheap DIY kit for a 60% (maybe even 40%) board, but all I come across are rather expensive ones. (The AMJ is $150+). I just need a case, PCB and plate. I honestly don't even care if the case is plastic. I just need to build a board, cheap, fast....
Any help in steering me the right direction would be helpful. Thank you.
Re: cheap 60% DIY kits?
« Reply #1 on: Tue, 24 July 2018, 20:22:36 »
Bro just buy a pre-built board and be happy DIY isn't for everybody.
Offline Leslieann
« Reply #2 on: Tue, 24 July 2018, 20:53:28 »
Search GH60 on Amazon and you will find all the parts you need.
case - $14
pcb - $30
stabs - $6 (spend more and get better ones)
Plate -  $23
Plate is optional and on a gh60, not as big of a deal as it is on something larger.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
Ergo Clears, custom WASD caps
| Das Pro
Costar model with browns
| GH60
« Reply #3 on: Tue, 24 July 2018, 21:05:49 »
But AugustCanaille could be super xpert soldering hero lvl 99..  we don't know Spam..
« Reply #4 on: Tue, 24 July 2018, 23:52:51 »
Good response. Hey, I wish I had the witticisms and knowledge you do. Maybe I should try to sit behind my computer and think of cool smart aleck comments to make, instead of helping someone. But that would take guts and integrity, of which you have none.
Have fun wondering what vagina tastes like.
« Reply #5 on: Wed, 25 July 2018, 06:00:30 »
 dumpster fire
« Last Edit: Thu, 26 July 2018, 07:30:48 by SpAmRaY »
« Reply #6 on: Wed, 25 July 2018, 08:05:04 »
Everyone chillax..
May one draw attention to Tp4's list of xpertise listed upon the left..
As ya'll can see.. There is no such lack of component comprehension ..
Offline ag36
« Reply #7 on: Fri, 27 July 2018, 19:54:35 »
GH64's software and keycap compatibility are pretty bad though.
Model M*5, SSK*4, M13 black*1, Model F XT*1, AT*1 F107*1, Unicomp*1, 3278 *1, Leopold FC750R*2, 980M*2 FC980C*1 Filco majestouch 2 TKL*1, Cooler Master MasterKeys S PBT*1, Uniqey Q100*2, Ducky pocket*1, KBD75*2, KBD19X*2, HHKB pro 2*1, Type-S*1 Topre Realforce RGB*1, 108 all 30g*1, numpad*1, 87U*1 Dell AT101W*2, Alps64*2, V80 matias quiet click*2, Quiet liner *1, WYSE ASCII *1
Offline Sup
« Reply #8 on: Sat, 28 July 2018, 19:21:59 »
I would just collect all the parts your self to make the diy kits. It isn't that hard tbh.
Case = Plastic,aluminium enough budget cases these days ranges from 40 -??? dollar for aluminium.
PCB = 60% DZ60 all the way. 35 dollars USB C possible
Plate = Cheap aluminium plate 15 dollars or even cheaper 10-15 dollars
stabs = 100% go for geniune cherry stabs clip/lube em optional tho.It's worth the extra costs! 10-15 dollars
switches = Gateron 0,20 each can't go really wrong with that. 65 switches 13 dollars at the moment at KBDfans.
Keycaps = depends on your taste. Enjoypbt blanks cheap and cherry profile great quality.
Aliexpress prices(exclude novelkeys)
Low profile aluminium case 40-45 dollars
DZ60 35 dollars
Aluminium plate 15,50 dollars
switches 13,60 dollars
Geniune cherry stabs - Novel keys. 8 Dollars excluding shipping. Not sure how much it would be i am from EU :p
Keycaps blank pbt cherry profile key caps 33 dollars
Total 150,10 dollars - It could be much cheaper if a plastic case is being used.
current
Coming soon
Offline ag36
Offline RehnMan
« Reply #10 on: Thu, 02 August 2018, 09:47:53 »
Anne Pro $70
Offline killyou
« Reply #11 on: Thu, 02 August 2018, 10:06:37 »
Best bang for the buck will be used/new Pok3r from ebay/mechmarket for $80-100. To get something better with DIY is going to cost you a lot more.
Offline Bigaku
  • コンニチハワタシノナマエハビガクデス Hello my name is Bigaku or ビガク
« Reply #12 on: Sat, 04 August 2018, 18:46:06 »
$100.98 for basic 60% on https://sentraq.com with keycaps and switches
HHKB Pro 2 With GMK Space Cadet
Colorways I'm supporting
