Author Topic: This seems obvious.  (Read 3825 times)
This seems obvious.
« on: Thu, 07 March 2019, 17:38:00 »
Unplug the Microwave before repairing.
/Maximum Oucho today.
Tp4 thought he were Xpert electronics guy,  Defeated by electricity
Re: This seems obvious.
« Reply #1 on: Thu, 07 March 2019, 17:48:30 »
Only 110 volts, could be worse :))
Did you fix it?  A microwave is one thing I wouldn't bother opening up as who knows what's going on in there...
« Reply #2 on: Thu, 07 March 2019, 17:51:57 »
The door switch gone bad, Honeywell brand spdt. (vbasic)
The intermittent connection degraded one of the relays.
Relays are omron.  I decided to go with replacement Omron switches instead of honeywell.
« Reply #3 on: Thu, 07 March 2019, 17:57:48 »
Good work - no point binning a working zapping box just because it doesn't know the door's shut.  I might have attempted that fix and having tried to tighten the screws inside a plug while the attached Christmas lights were glowing next to me it might have had a similar outcome...
Offline fanpeople
« Reply #4 on: Fri, 08 March 2019, 04:06:28 »
The next trick is the remove the door to the microwave, defeat the Darwin switch and set it to constantly on.
This way you never have to waste time setting the microwave or opening the door.
Offline absyrd
  • CPT HYPE PADAWAN
« Reply #5 on: Fri, 08 March 2019, 04:43:54 »
This guy knows how to get super powers.
« Reply #6 on: Fri, 08 March 2019, 07:15:41 »
25 yrs of HungryMan microwave meals + Costco chikam aught to provide near equity.
« Reply #7 on: Fri, 08 March 2019, 07:23:54 »
The wifu caught popcorn on fire in the microwave the other day.
Offline invariance
  • ...here with all the other boson's
« Reply #8 on: Fri, 08 March 2019, 17:02:06 »
The smell of burnt popcorn has been known to permiate through a whole suburb for days.
The only BS I
want to hear is
from a Model M:
PN:1391401
DOB: 04FEB87
      Wyse 85      Mtek K104
SMK Blue: Chicony KB-5181; HyperX Aqua: HyperX Alloy Origins *Yet-to-rebuild: A 69 key C. P. Clare Foam & Foil assy *Rubber: Digital LK46W-A2; uSoft Natural Pro RT9401, Natural Multimedia 1.0A RT9470, Natural Ergonomic 4000 KU-0460; "Avid" Sejin SLKR2233; "Diamond Touch" Mitsubishi 6511-PB
« Reply #9 on: Fri, 08 March 2019, 18:31:53 »
What's really in the corn..
Offline Leslieann
« Reply #10 on: Sat, 09 March 2019, 00:52:57 »
110v is the input.
All it takes is a decent sized capacitor in there and the voltage can go MUCH higher, people have been killed opening unplugged PC power supplies this way.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
Ergo Clears, custom WASD caps
| Das Pro
Costar model with browns
| GH60
« Reply #11 on: Sat, 09 March 2019, 07:26:00 »
110v is the input.
Well, the Kill thing is usually only peeps with atherosclerosis, The spontaneous shock causes rupture in their arterial plaque, dumping cholesterol laden endothelial scar tissue into their bloodstream. Typically resulting in a heart attack ontop of residual brain stroke.
« Reply #12 on: Sat, 09 March 2019, 13:46:41 »
110v is the input.
I've felt unplugged PSU too - it got stuck to my hand until I slowly slid it to the edge of the desk and gravity took over.  I thought it hurt more than mains but why would a 230-12V converter go higher first...
My friend did the big electric shock thing best though, he was sat on his feet and the shock straightened his legs and he flew to the other end of the bed.
« Reply #13 on: Sat, 09 March 2019, 14:46:55 »
110v is the input.
Yup.. it's most dangerous, if the hand clasps around the live wire.. THEN u DIE.
- D Trump 2026-10-24
« Reply #15 on: Mon, 11 March 2019, 11:03:27 »
https://www.asc.ohio-state.edu/physics/p616/safety/fatal_current.html
Thanks for that, explains a lot.  Interesting that more or less is somewhat OK but right in the middle you just die :eek:
« Reply #16 on: Mon, 11 March 2019, 11:51:38 »
Interesting that more or less is somewhat OK but right in the middle you just die.
I think that the really big jolts blast you away and disconnect you quickly, and the worst case is when you spasm but stay in place.
