Author Topic: Hair Dryers..  (Read 5617 times)
Hair Dryers..
« on: Mon, 13 July 2015, 01:27:00 »
Hai guys.
Any ya'll has experience with a --powerful-- foldable travel dryer?  has to do 220 and 110.
Re: Hair Dryers..
« Reply #1 on: Mon, 13 July 2015, 09:38:08 »
What...  like.. no one drys their hair ne-more ?
Offline azhdar
  • Praise the AZERTY god
Re: Hair Dryers..
« Reply #2 on: Mon, 13 July 2015, 09:39:49 »
I don't know a single man that dry his hairs.
A towel is good enough.
Azerty Propagandiste
Re: Hair Dryers..
« Reply #3 on: Mon, 13 July 2015, 09:42:11 »
Um..... well... if it's very short, you don't need it..
But if you want your hair to --look-SUPER-cool--..    you need the hairdryer..
The point is,   it makes your hair look good,  AND it dries your hair faster.
Offline evolveS
  • ಠ_ಠ
Re: Hair Dryers..
« Reply #4 on: Mon, 13 July 2015, 09:58:15 »
I'm sure there's plenty of travel product review sites out there that cover this; they may not be targeted to men but who cares?
Just pack lighter and get a full-sized hair dryer.
"money comes and goes, but doubleshots are forever"
-a petty thief
Offline absyrd
  • CPT HYPE PADAWAN
Re: Hair Dryers..
« Reply #5 on: Mon, 13 July 2015, 10:04:15 »
Shave head. Win.
Offline inanis
  • Truly Literally The Cloud
    • SEALWoodworking
Re: Hair Dryers..
« Reply #6 on: Mon, 13 July 2015, 10:05:36 »
I didn't even know they make folding hair dryers. I have a regular hair dryer, that works good and doesn't take up a lot of space. How much power do you need to dry those manly locks?
Re: Hair Dryers..
« Reply #7 on: Mon, 13 July 2015, 10:07:16 »
Um...  it says 1875watts on the box of the one I have, but in testing, it only pulls 1300 watts, I was disappointed.
but 1300 is sufficient..
I don't know why they would put 1875 on the box when it only pulls 1300..
Offline inanis
    • SEALWoodworking
Re: Hair Dryers..
« Reply #8 on: Mon, 13 July 2015, 10:08:29 »
The answer to this questions is easy: So you'll buy it.
Re: Hair Dryers..
« Reply #9 on: Mon, 13 July 2015, 10:10:11 »
Well,  I originally thought it was perhaps, they're designing to the load spec of older houses which may be 10 amps instead of 15/20..
But, yea.. THEY LIED
Offline azhdar
Re: Hair Dryers..
« Reply #10 on: Mon, 13 July 2015, 10:10:58 »
sue them !
Re: Hair Dryers..
« Reply #11 on: Mon, 13 July 2015, 10:20:53 »
I'm actually surprised no geek has said,  Real men dries hair with Heat gun.
Offline F1620mm
Re: Hair Dryers..
« Reply #12 on: Mon, 13 July 2015, 10:34:27 »
tp4tissue, how did you test your hair dryer for the amount of watts used?
  • Live long and prosper
Re: Hair Dryers..
« Reply #13 on: Mon, 13 July 2015, 10:36:31 »
Real men dry hair with stationary air
tp thread is tp thread
Offline azhdar
Re: Hair Dryers..
« Reply #15 on: Mon, 13 July 2015, 10:47:23 »
Re: Hair Dryers..
« Reply #16 on: Mon, 13 July 2015, 10:47:53 »
I got der' Kill-A-Watt meter on amazon.
http://www.amazon.com/P3-International-P4460-Electricity-Monitor/dp/B000RGF29Q/ref=sr_1_2?ie=UTF8&qid=1436802338&sr=8-2&keywords=killawatt
Maybe your Kill A Watt isn't working correctly?
I checked it with my amp meter,  it checks out.
Basically,   the killawatt only goes to about 13-14 amps on 120v,   so  if it's measuring anything AT ALL,   that means it's LOWER than 1500watts.
Offline azhdar
Re: Hair Dryers..
« Reply #17 on: Mon, 13 July 2015, 10:48:43 »
and did you checked the amp meter?
Re: Hair Dryers..
« Reply #18 on: Mon, 13 July 2015, 10:49:23 »
Re: Hair Dryers..
« Reply #19 on: Wed, 15 July 2015, 18:56:53 »
Got my hair dryer..
Pretty solid..  LIES on the 1875 watts AGAIN,  only 1440 watts this time....
Offline hwood34
  • underwater squad
  • #1 CL stan
    • Keyboard Illuminati
Re: Hair Dryers..
« Reply #20 on: Wed, 15 July 2015, 19:06:39 »
So there's this cool thing called google that's super for this type of question
Offline Axollott
Re: Hair Dryers..
« Reply #21 on: Wed, 15 July 2015, 19:07:59 »
Real men dry their hair with hot air from GPU fans
Re: Hair Dryers..
« Reply #22 on: Wed, 15 July 2015, 19:13:30 »
Hrrrrm........  I'm pretty sure  this WOULD work, with a quad SLI setup
You would need the reference blower type coolers.
A custom duct, to concentrate the air from all 4 GPU..
ALL together,  you'd get something ~ 1000 watts of hot-air..
Offline Jokrik
Re: Hair Dryers..
« Reply #23 on: Wed, 15 July 2015, 19:16:18 »
I do hair dry my hair everyday,
that's because I can't stand wet hair and need to user wax
a single (I think 2500w-ish) hair dryer would only take me 30 sec to get my hard dry lol
Re: Hair Dryers..
« Reply #24 on: Wed, 15 July 2015, 19:18:23 »
It's less about the drying..  and m0re about the Lift..  gives you that cooler looking hair-texture..
But the drying is also important...
Because it reduces bacterial buildup on the scalp.. (not an issue in dry climates) if you live in more damp enviro..
Offline Jokrik
Re: Hair Dryers..
« Reply #25 on: Wed, 15 July 2015, 19:21:49 »
But if you live in more damp enviro..
with hair dryer if you blow your hair at the right angle, you don't even have to use wax to style
it would stay like that for a while  ^-^
Hair dryer is the future people!
Re: Hair Dryers..
« Reply #26 on: Wed, 15 July 2015, 19:28:00 »
well.. that depends on how your hair is cut ONTOP of the Drying-vector.
As for staying power without styling-products..  in the winter, you're looking at ~ 2-3 hours.
In the summer,  when it's hot, and you're sweating,   ~ 20 minutes tops..
Hair-dryer was the future..   but that future is Here NOW...
Offline Leslieann
Re: Hair Dryers..
« Reply #27 on: Wed, 15 July 2015, 19:30:06 »
Most US household circuits are rated for a bit over 1500 watts, hence why they are all rated the same.
Heat is bad for your hair, if you have really long hair, you never let a dryer near it. Hot showers are bad enough. Once hair hits/passes your shoulder blades, it's hard enough to keep it from breaking and splitting without drying it out with a blow drier.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
Ergo Clears, custom WASD caps
| Das Pro
Costar model with browns
| GH60
Re: Hair Dryers..
« Reply #28 on: Wed, 15 July 2015, 19:33:40 »
Well,  if you have the thinner type of hair that is very susceptible to damage, there are those creams they make specifically for use with hair dryers.
Offline hwood34
  • underwater squad
  • #1 CL stan
Re: Hair Dryers..
« Reply #29 on: Wed, 15 July 2015, 19:36:07 »
I try not to absolutely kill my hair by at least just setting the speed to the highest setting but putting it on "cool"
Re: Hair Dryers..
« Reply #30 on: Wed, 15 July 2015, 19:38:22 »
Your dryer has independent speed and heat control ?
Hrrmm.. maybe i should get one of those.. but I didn't see one that does 220 and 110..
