Author Topic: Gaming PC Parts discussion thread.  (Read 305396 times)
Offline Sniping
Re: Gaming PC Parts discussion thread.
« Reply #850 on: Fri, 22 August 2025, 18:18:50 »
Unless intel's laptop iterations are much cheaper than AMD, Tp4 can't think of a single good reason to buy any intel mobile chips.
The iGPU on AMD works so much better.
Not sure what your laptop use case is, but Macbook is an awesome product right now if you ask me. You can find an M1 Macbook Pro or M2, M3 or M4 Macbook air for around $600 or so used, and a tad more new. Fanless design is awesome for me and laptop never gets warm for normal use. I like that they hold value well too, chassis build quality and microphone quality is great.
« Reply #851 on: Fri, 22 August 2025, 21:41:11 »
Took a chance and sprung for some used RAM sticks from Shenzhen, CORSAIR DOMINATOR-GT 4 x 8GB DDR3 1866
The Sabertooth Z77 is notoriously picky with the ram it likes, and 16gb is just not cutting it sadly even being oc'd to 2133
Why is DDR3 still so damn expensive though? $120 for 32gb of used ram, and that is on the cheaper side
« Reply #852 on: Fri, 22 August 2025, 21:47:51 »
Not gonna lie NT, you're being stupid, LOL.  You clearly don't even understand what you're playing with and how it's affecting the system.
It's not sabertooth, all 77 and 97 barely did 4 sticks at 1600 with loose timings.   If you wanted 4 at any decent speeds, it had to be manually tuned. The auto-training would fail pretty much across all boards.
Even if you get it to post, it's probably not bench stable,  stable enough to run counterstrike, but it's randomly corrupting data.
Buying more parts to fix something  "in the wrong way"  to ultimately achieve  "Lower performance" is what your current trajectory is.
Offline Leslieann
« Reply #853 on: Sat, 23 August 2025, 09:22:36 »
Quad sticks haven't been good for overclock for a while and the last few years haven't really been stable even at stock speeds.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
Ergo Clears, custom WASD caps
| Das Pro
Costar model with browns
| GH60
« Reply #854 on: Sat, 23 August 2025, 10:43:20 »
It's because of the memory traces topology of the mobo. They're daisy chained, so the signal strength gets split, hence lower sustained frequency. It wouldn't be a problem if they went quad channel.
Well, problem is cost.
It might make sense just to solder ram at this point. I have trouble seeing the benefit to more than 64gb of ram.
Solder can hit 8000 easily, whereas socketed will take much longer to hit that consistently.
By the time, someone decides they need that much, they might as well buy a new platform.
The reasoning now probably is, most applications are not memory bandwidth bottlenecked, so the expense in the area of ram isn't worth it.
It's cheaper to put more  HBM on the cpu, than to make all new ram sockets, new topology. Soldered makes sense, but I guess they're afraid the market won't accept it.
« Reply #855 on: Sat, 23 August 2025, 14:37:35 »
You guys remember how you could sit on PC cases,  Tp4 remembers.
Not today though, they're all so flimsy.  Wouldn't handle a drop from no table.
« Reply #856 on: Sat, 23 August 2025, 15:14:04 »
I always heard quad lanes distribute the workload more evenly? Is that not true? How can bottlenecking the hardware to half the slot access possibly be faster?
« Reply #857 on: Sat, 23 August 2025, 23:24:23 »
some copper plates for my 870 EVO's  :cool:
« Reply #858 on: Sun, 24 August 2025, 01:03:18 »
Unless you take the drive apart to get a bigger piece of silicone pad on the controller on the inside, Chances are the dollop they used internally is already dried out.
Tp4 has taken several sata ssds apart.
They also usually don't even silicone the flash, only the controller to cut cost.
Check the video, samsung on the 870 evo literally don't even put silicone on it at all.  You have to take it apart and put in your own.
Without silicone, more heatsinks are worthless, it's probably worse, and runs hotter.
« Reply #859 on: Sun, 24 August 2025, 08:43:54 »
In theory, you can run a whole city off 1 computer.
If there were no other computers, or any network, you don't need security/ encryption.
If it just came down to coding to the metal of a modern cpu,  without all the fluff, you can get ALOT of database throughput.
« Reply #860 on: Sun, 24 August 2025, 16:27:24 »
A bit confused,
If they're going to sell strix halo in $2000 laptops. Why would anyone buy that, when 3070ti laptops are $1000, and almost twice the gpu mem bandwidth as it doesn't share system ram.
Is it just for LLM people buying those 128gb boxes?
« Reply #861 on: Tue, 26 August 2025, 11:30:38 »
Headsup, ok,  DO NOT buy uxcell bearings on dat Amazon.  They're pretty darn bad. Feels like sand.
« Reply #862 on: Tue, 26 August 2025, 12:36:18 »
People sayyy they want APUs for desktop, but don't think there are that many actual buyers.
Because the used discreet cards aren't that expensive, a very shiny new APU would cost more and probably have less performance.
The box is limited by board size, so it's going to come out about the same with or without APU, and if you want a Niche small box that ONLY fits an apu build,  that is yet another cutoff which increases cost.
APU really should just remain laptop oriented. It doesn't make sense for desktop whatsoever outside of corporate endpoints.
A basic cpu + 3 year old discreet gpu will almost always outperform any $500-600 apu box and come out, at least $100 cheaper.
« Reply #863 on: Wed, 27 August 2025, 14:23:58 »
X220 prices are still inflated because of it's UNREASONABLE, h4x0r status.
It's a great laptop, but I mean, $200 for base, and you still might need new IPS + battery + ram + PTM7950.
It'll come out to $400 when you're done, $400 new would just about buy an 8core state of the art Zen5 mobile .
-not to mention, the x220's Achilles heel,  you have to take apart the whole mobo to fully clean the fan.
It was designed by the japanese lab, horrible laptop designers, almost as bad as germans.
« Reply #864 on: Wed, 27 August 2025, 15:44:39 »
Ok, seriously,  Home PCs are no place for electric screw drivers.
Even the ones with electric braking, they're not fast / responsive enough to not strip small screws.
« Reply #865 on: Wed, 27 August 2025, 20:08:51 »
Tp4 has coooled on the ryzen 350, very variable depending on dissipation configuration.   /Not Recommended.
« Reply #866 on: Wed, 27 August 2025, 22:56:53 »
Amazon has really been getting bad lately for computer parts. First I get a used ssd with sensitive info on it, now I got a case fan someone swapped out for a different brand, returned and got a replacement, only for it to arrive coated in dust and scratches clearly used.
Whatever horrible policy they have where they ship out defective and used returns as new items has got to stop. Obviously a $$$ policy so they can get away w/ selling used **** for new.
« Reply #867 on: Thu, 28 August 2025, 07:53:23 »
Laptop decisions.
Tp4's head is bout to explodz.
Toooooooo many laptops.   we should just have,  laptop 1, laptop 2, laptop 3.
WHY do we need laptop #39,938
« Reply #868 on: Thu, 28 August 2025, 08:56:28 »
Oled on laptops,  Thoghsts ??
« Reply #869 on: Thu, 28 August 2025, 11:58:11 »
My decade-old Thinkpad T440p is so good I got a backup.
Elon Musk — infamously declared that
'The fundamental weakness of Western civilization is empathy.'
« Reply #870 on: Thu, 28 August 2025, 12:12:39 »
Wurd on the dark web is, all the new gear is full of corpo hardware backdoors, and the real Hax0rz stick to trad gear.
« Reply #871 on: Thu, 28 August 2025, 15:29:37 »
Gaming laptops are huge money makers, because they give you all the junk salvage parts that wouldn't make it as a desktop chip.
Then they're woefully under-cooled, so they burn out, and you'll have to buy a new one in a couple years.
It's a SCAM.
« Reply #872 on: Mon, 01 September 2025, 17:26:59 »
Ok, this is kind of a weird design choice.
The laptop will intiate fast charging,  but then below 40% battery, it will throttle the cpu+gpu and deliver as much charge to battery as possible.
WHY do this?  If you're going to do this, LET ME CHOOSE whether I want that.
For example,  If I have 20% or even 10% battery, and it's plugged in, there are more circumstances where I would want more performance over faster battery charging..
/Raises eyebrow
« Reply #873 on: Mon, 01 September 2025, 19:54:59 »
Headsup, so the asm2464pd DOES in fact pass through 4x pcie on USB 4.0 port or Thunderbolt4 x4 ports.
But on lower ports, it can't.
Ooof, just realized this laptop came with disgusting QLC ssd. sigh... disgusted.
« Reply #874 on: Tue, 02 September 2025, 21:25:31 »
Just got Anker's new model GAN 70w 4 port charger from costco, (Zolo) branded series.
Testing it out running a flat 60w load. Let's see how long it can go before shutting off.
Taking all bets. :D
26C ambient.
-11min, 42C skin temp, holding 60.
-17min, 48C, holding
-21min, 50C, holding
-26min, 53C, holding, seems to flicker to 58w-60w now, may be the beginning of ramp
-31min, 56C, holding
-37min, 57C, holding
-44min, 60C, holding
-55min, 61C, holding
-63min, 62C, holding
-73min, 63C, holding, 57-58.5w now. May be giving in.
-84min, 64C, holding, between 57-59, guess it's holding.
-98min, 63.5C, holding, 57-58.
-113, 64C, holding 57-59
Seems this is steady state, and it will hold 60w.
Testing 2 device charge, it will negotiate for lower peak, 54w
This is a good charger overall. Probably get a 100w charger if you need to charge laptop + cellphone at the same time.
But this is a great deal for the 70w unit + 30w unit + 2x 240w capable cables (48v5amp)
For $30, can't get better than that. Prolly hit $25 by holiday.
« Reply #876 on: Sat, 06 September 2025, 19:24:35 »
So my RAM woes turn out to be due to having the 3rd and 4th slots on my mobo being burned out. Dual stick setups only.  :'(
« Reply #877 on: Sat, 06 September 2025, 22:47:38 »
If you use a laptop in the center of a square room, and the fan's goin fast,  you can hear power saw noises because of the reflections. It sounds like there are table saws going off into the distance.
« Reply #878 on: Sat, 06 September 2025, 22:56:10 »
Ohmygerd. Actually another function that can use the NPU, AI noise canceling voice recording. It activates through Intel's integration thingie, You have to record part of your voice through the realtek console.
LOL. the NPU goes up to 11% utilization when you turn on the function.
It cuts out fan noise decent. Althoughhhhh, sometimes it cuts your voice out too. LOL.
So... not really that much better than regular noise canceling.
« Reply #879 on: Sat, 06 September 2025, 23:00:04 »
CF toilet seat
Carbon fiber is so beautiful. And I can imagine that a cool lightweight material would be a plus. Too bad it is so expensive.
« Reply #880 on: Sun, 07 September 2025, 09:16:24 »
45% and 60% SRGB laptop screens.
Seriously, WHY even make them, those fractions of pennies aren't worth it.
The losses on cost of returns on people buying online goods that don't match photos far exceeds the savings.
This is atrocious.
« Reply #881 on: Sun, 07 September 2025, 16:00:15 »
We really shouldn't be making Laptops with USBC only charging.
This is not a good move. They're not physically as durable as barrel plugs, and electrically, you have a complicated PID controller with mosfets that can fail.
It would be easier, if we just standardized a Barrel plug across all manufacturers.
Trivial to design, Size will be uniform and quite small, considering 99% of laptops will not top 200w requiring exotically large ports.
« Reply #882 on: Mon, 08 September 2025, 01:17:48 »
Figured out the weird instability on the zen 7000 and 9000 cpus
So, what happens is,  if the CPU is hot vs cold,  that can impact the ram training.
Hot training can skew the numbers enough to cause instability.
For example, you run a 24hr stress test, and it's stable,  but you reboot immediately while hot, and suddenly it won't boot or crash after windows.
But you let it cool off for 20 minutes, then using the same settings, you can run another 24hr stress test and it's still stable.
AMD reallllly needs to get rid of this memory controller, it's just too touchy.
« Reply #883 on: Fri, 12 September 2025, 17:02:05 »
PS6.
Honestly, having 9070xt/7900xtx lvl raster is not enough if they're planning 2027 release.
Also, Tp4 is not so sure it can even reach that at 160watt in 3nm, they'll probably need 250watt at the very least.
The speculated 5090 lvl path-tracing performance,  this is easily possible if there's special die space with dedicated hardware to do it.   But only getting that much in 2027.
Well.  If they hit $500-600 for the whole machine,  it's not bad,  but meh....    4K 120 should be the benchmark. 60hz target is unacceptable..
« Reply #884 on: Fri, 12 September 2025, 21:13:53 »
Sigh.
Dramless SSDs,  invented to torture poor people such as the Tp4.
314564-0
« Reply #885 on: Tue, 16 September 2025, 20:23:18 »
Honestly,  PSU and GPU makers need to STOP doing 0-rpm.
0-RPM is unnecessary, you can not hear 200-300 rpm, and yet 300 rpm will get you a 20 Degrees difference on ICs at idle wattages.
The ICs don't care, but the components AROUND the ICs care immensely.
0-rpm is just asking to die in the middle of the bathtub curve.
Offline phinix
« Reply #886 on: Wed, 17 September 2025, 03:22:26 »
Sigh.
Yeah, I hate that too. Hate when SSD is trothling down. I was shifting large amount of movies recently and my ssd kept dropping down significantly and istead of "fast" USB-C drive speeds, I had miediocre speeds dropping from 800MB/s to around 90MB half of the time...
12100 | 9070XT | 2TB SSD | ROG STRIX B760-I ITX | 32GB RAM | SFX 850W | NR200p | Ruark Audio MR1 Mark II | LG OLED 42C4
Realforce 87u55 | CM QuickFire Rapid MX Blacks | Filco TKL 85g Gateron Oil Kings | Tiger Lite 85g Oil Kings | Logitech Pro Superlight
GSA: Retro High-light  HSA: Hyperfuse  XDA: Canvas  PBS: MV Classic
« Reply #887 on: Wed, 17 September 2025, 08:55:45 »
They're ok for game drives and general usage, but I feel like the saving of that single ram chip is kinda unnecessary.
« Reply #888 on: Wed, 17 September 2025, 14:00:57 »
Ok, 9955hx3d.
This is reallllly wasted in a laptop. These chips really need 200watts to shine, and they don't get that in a laptop chassis.
The other problem is, it seems they're not using soldered ram for some reason on alot of chassis, so it's not even sold w/ ddr 6000.
If you're going to spin this much silicone at least juice it to 7600mhz on ram.  Wasted potential there too.
The total chassis weight is pushing 8lbs + 3lb power brick.   Max total dissipation is 375 watts, That IS impressive, although at quite an unreasonable noise lvl.  It's literally right in your face being a laptop.
Ill-conceived.
We really should embrace Egpu if anyone wants to go about 200watt, at which point it's so impractical a machine that it's just not a good experience for the customer.
« Reply #889 on: Wed, 17 September 2025, 22:32:13 »
Anime figurines in PC cases,
Thoughts?
Good trend, bad trend?
« Reply #890 on: Fri, 19 September 2025, 10:55:36 »
Woah woah woah,
Finallllly,  Fan control changed hardware i/o interface.  Now no longer constantly being flagged by WinRing0 by microsft defender.
Top wurk.
Among the Greatest pieces of fun community software.
Offline phinix
« Reply #891 on: Sat, 20 September 2025, 19:47:35 »
Not entirely gaming related, but still.
I just receivved my new bluetooth headphones - Marshall Monitor III ANC.
My first BT headphones - they sound lovely, amazing experience, HOWEVER - I just watched youtube video with conversation and noticed huge lag! Then... played a game on PC... there is about 0.5sec lag! Its very noticible when playing game or watching people talking. I think bluetooth drivers are up to date, same my headphones. How the hell can I reduce this lag?
« Reply #892 on: Sat, 20 September 2025, 20:11:39 »
LOL, should've consulted Tp4-supr-ntellignce before hand.
Kekeke.  yea bluetooth have anywhere between 60-150ms of lag.
The only headphones that don't have this problem use their own dongles. Like the Logitech gaming headphones, but the expensive versions are pretty jank. They're not really durable products.
Headphones however, is not a complicated device.
The way headphones work, is by moving a diaphragm identical to speakers.  But because the diaphragm is right next to your ear, it doesn't have to move very much (fractions of a mm), So while it's very difficult and require exotic engineering to build a Low-Distortion, clean sounding SPEAKER (that moves maybe centimeters to inches),  a $0.02 headphone diaphragm in a $35 headphone, is more or less identically performant as a $1 to $25 diaphragm in $5000 headphone, because there's no distortion, it doesn't move very much at all to produce 70-80db right next to your ear.
In the audio market, most of it is markup.  The headphone has virtually no distortion outside of spatial distortion, which can be handled in software.
So, yea,  buy a g535 or g435, call it a day, it's 99% as good as the Sennheiser HD800.
Most headphones marketed like HD800, like nike jordan sneakers, are in a class of Veblen goods.  They're very generic low tech products, but made very expensive, because consumers on average are ignorant of the Physics of what's happening.
You look at a 98 Inch Tv with thousands of dimming zones, multichannel speaker, a whole damn computer built inside using Arm based pentonic chipsets that can process 4K 165hz, transform it 5-10 times before that even hits a refresh, backlight zone control, and that is only $1500.
And you look at your Speakers / Headphones which cost $1500.    You open them up, some glue, a couple $1 speaker cones,  The most expensive thing on it is the wooden box, very low tech, no 3D FEA modeling, nothn'.
The existence of such products, mark differences in HUMAN classification. The intelligence strata.
« Reply #893 on: Sat, 20 September 2025, 21:52:00 »
Modern GPUs are so gigantic they take up/cover 4 slots on my mobo - 2 PCI16x and 2 PCIe slots
You'd think they would lay out mobos different to accommodate these giant slabs, but actually no!
« Reply #894 on: Sun, 21 September 2025, 12:31:11 »
Tempted to get new Samsung oled, it has a reallllly high peak brightness cap. The coating is holding Tp4 back, because Tp4 must have glossy especially for QD-oled, Matte-coating smears/ scatters oled light..
« Reply #895 on: Sun, 21 September 2025, 22:52:13 »
Sss...  It doesn't look like they're going to make a Glossy 77 qd-oled any time soon.
Hrrrmm.
One would guess, tandem is the middle ground in the next few years before those non-organic phosphors happen.
But Tandem may not get to the 4000nits reliably. And soon they'll move to 10000nits.
« Reply #896 on: Mon, 22 September 2025, 11:35:12 »
Cold rainy day,
550watt Arm0r(r0re keeps Tp4's room nice and toasty.
« Reply #897 on: Mon, 22 September 2025, 20:41:30 »
It's actually Kindddd-of-weird,  that they haven't figured out how to make LARGE laptops have the same battery life as smaller ones by turning off the D-gpu.
I mean, seems like a no brainer to figure out. Why is this so hard, and why haven't they worked on it?
The latest + greatest,  Arrowlake hx series,  on ultramobile, they can get almost lunarlake lvl battery life.
Yet on the MOST-Expensive desktop replacement chassis, these laptops pull 4 hour battery web-browsing, like, what???
« Reply #898 on: Wed, 24 September 2025, 23:24:16 »
Gaming handhelds.
Tp4 thinks it's just wrong.
Cuz with a 7 or 8 inch screen, at arms length, it's equal to or smaller than a 14" laptop at desk distance.
You add the fact that you have to hold it, it's heavy, and you don't get much performance out of it. Seems like a laptop is still the way to go.
Put it all in a bag, 14" laptop is still easier to carry due to profile.
The cost on these new handhelds also,   Laptops already offer poor performance per dollar, the handhelds are even worse.
It's the wrong direction in ergonomics, visual quality, performance, battery life.
« Reply #899 on: Thu, 25 September 2025, 10:27:11 »
If you guys keep buying Dramless,  they'll never stop making them.
STOP BUYING DRAMLESS..
