Author Topic: What's Bothering You? (The thread about what is bothering you.)  (Read 7869048 times)
0 Members and 9 Guests are viewing this topic.
Offline crickclackman
Re: What's Bothering You? (The thread about what is bothering you.)
« Reply #15000 on: Wed, 24 February 2016, 11:36:06 »
uh no, everybody knows cherry keycaps don't fit red MX. they only fit cherry blues and only TKL form factor. noob.
What's TKL?
TKL is Tenkeyless.
Offline bcredbottle
« Reply #15001 on: Wed, 24 February 2016, 11:59:21 »
lol im not getting muted
$20 on PP says it happens in the next 60 days
Who called it?
Offline whmeltonjr
« Reply #15003 on: Wed, 24 February 2016, 12:03:14 »
« Reply #15004 on: Wed, 24 February 2016, 12:04:14 »
#freebee
#freemoose
#freekirk
#downwithmods
#hashtagsforconvos
Offline dgneo
  • Supervillain
« Reply #15005 on: Wed, 24 February 2016, 12:06:16 »
****ing turntable. one thing after another.
« Reply #15006 on: Wed, 24 February 2016, 12:53:54 »
what happen
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
« Reply #15008 on: Wed, 24 February 2016, 12:59:38 »
You know what I can't stand?
A broken table.
Offline btctopre
« Reply #15009 on: Wed, 24 February 2016, 13:02:08 »
80%
« Reply #15010 on: Wed, 24 February 2016, 13:03:35 »
80%
Your princess will be back soon enough.
Offline hashbaz
  • Grand Ancient One
  • * Moderator Emeritus
« Reply #15011 on: Wed, 24 February 2016, 13:09:36 »
What's TKL?
TKL is Tenkeyless.
Isn't "10" two keys though? These keyboard terms are so confusing.
« Reply #15012 on: Wed, 24 February 2016, 13:10:24 »
#freebee
#freemoose
#freekirk
#downwithmods
#hashtagsforconvos
Did new drama happen?  I don't think I can keep up with the daily juice anymore.
Offline dgneo
  • Supervillain
« Reply #15013 on: Wed, 24 February 2016, 13:10:30 »
what happen
Needle?
Well...
Replaced the belt as I had mentioned somewhere around here, and I had thought that fixed it, as the first time I tested it, it played fine. Well the same issue started cropping up again, it seemed like the belt was slipping, but in reality it's the motor that kept stuttering. So I talked with LSB (as he has the same SpeedBox as me), and he agreed to try the original power supply for the TT. I thought I knew where it was, however I think it's back at my parents house.
Anyhow, I checked the specs of the OEM Power Supply, and lo-and-behold, the Power Supply for the Speedbox is the same specs and plug. So I plug that directly into the TT, and it spins beautifully! No more stuttering, I can make it through a whole record no problem. I took apart the Speedbox shortly after, and confirmed it was bad, as it has a blown cap and what looks like 2 fried resistors.
Only issue(s) now are:
1. I can only get regular 33rpm LPs to play when the band is around the 45rpm spindle. If I place the band around the 33rpm spindle, the record plays too slow. I've double checked the instruction manual (which the image linked above is from), so I'm not sure what's causing this. Ironically, I also tried my Kid A 10", and that has to be played on the 33rpm spindle, otherwise it's too fast. dafuq  :mad:
2. Ground loop in my current setup. All the components use power warts, so none of them have a proper ground. Need to figure out what to do here.
So at this point, I'm not exactly sure where to go. I need to locate the original power supply, but it shouldn't make a difference as this one has the same specs.
« Last Edit: Wed, 24 February 2016, 13:47:50 by dgneo »
Offline hashbaz
  • Grand Ancient One
« Reply #15014 on: Wed, 24 February 2016, 13:11:46 »
#freebee
#freemoose
#freekirk
#downwithmods
#hashtagsforconvos
#baz
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
« Reply #15015 on: Wed, 24 February 2016, 13:18:05 »
what happen
Needle?
Well...
Direct drive bruh
Offline ANightOnCloudNine
« Reply #15016 on: Wed, 24 February 2016, 14:02:23 »
Can't eat nothing until my surgery is done,
Offline inanis
  • Truly Literally The Cloud
    • SEALWoodworking
« Reply #15017 on: Wed, 24 February 2016, 14:35:40 »
I'm in the world's most uncomfortable meeting. My boss is giving someone the business and watching this guy try to dig himself out of a hole is getting uncomfortable. Everything he says makes it worse, even if he is saying the right thing. 34 minutes in, and it just keeps getting worse. I need to gtfo of here.  :blank:
« Reply #15018 on: Wed, 24 February 2016, 15:38:36 »
We have different definitions of "giving somebody the bidness" ಠ_ಠ
« Reply #15019 on: Wed, 24 February 2016, 15:39:33 »
Right?  No way that would take 34 minutes.
Offline Bromono
  • Wanabe Cicerone
  • HHKB > Your Opinion
« Reply #15020 on: Wed, 24 February 2016, 15:42:36 »
LOL reading it from that perspective makes it so awesome
Offline trizkut
« Reply #15021 on: Wed, 24 February 2016, 15:42:58 »
« Reply #15022 on: Wed, 24 February 2016, 15:45:47 »
Hm digging himself out of a hole.. inanis where the hell do you work ಠ_ಠ
Offline inanis
    • SEALWoodworking
« Reply #15023 on: Wed, 24 February 2016, 15:47:46 »
1.) I said "business" not "bidness". Terms mean different things!
2.) In hell, demik, I work in hell.
3.) My boss loves to set people up to fail. He'll just keep asking the same question over and over again non stop. There is no winning and there is no end.
« Reply #15024 on: Wed, 24 February 2016, 15:49:55 »
Bidness business potato potato
Is your boss my father? So that's where he went when he went to go buy cigs and never came back
« Reply #15025 on: Wed, 24 February 2016, 15:50:27 »
I used he went too many times and that bothers me
Offline Bromono
  • Wanabe Cicerone
« Reply #15026 on: Wed, 24 February 2016, 16:09:06 »
to be fair, he asked where in hell you worked.
stipulation.
By the sounds of it I would say the seventh circle
(lets see if anyone gets that reference)
Offline inanis
    • SEALWoodworking
« Reply #15027 on: Wed, 24 February 2016, 16:13:48 »
That is what modify post is for! I know you know how to use it. Like me you sneak in edits before the system catches them with a "modified" stamp.  ;)
stipulation.
Violence? I'm more in Anger mode. I rarely escalate to violence. But I exist in Anger (which is 5th) more often then I like.
Offline trizkut
« Reply #15028 on: Wed, 24 February 2016, 16:18:56 »
But then someone quotes you while you're doing damage control and ruins everything :p
Offline inanis
    • SEALWoodworking
« Reply #15029 on: Wed, 24 February 2016, 16:21:10 »
Luckily I never post anything I wouldn't want seen. But I'm a terrible speller and don't pay enough attention. Then as soon as I hit post I'm like "OMG WHAT HAVE I DONE!". Always after I hit post tho. I could preview it for 5 minutes and re-read it over and over again and it'll look fine.
EDIT: I even did it on this post. :(
« Reply #15030 on: Wed, 24 February 2016, 16:59:59 »
I'm here for the bidness giving and hole digging.
« Reply #15031 on: Wed, 24 February 2016, 17:23:19 »
Digging holes is very hard.... much harder than it looks on the TV.
Offline mobbo
  • u fk
« Reply #15032 on: Wed, 24 February 2016, 17:23:59 »
****ing what
Quote from: Binge
« Reply #15033 on: Wed, 24 February 2016, 17:25:53 »
No it isn't.
Well, then again, I'm Mexican, so I guess lawn work comes easy for me.
amiright demik?
Offline BlueNalgene
« Reply #15034 on: Wed, 24 February 2016, 17:28:38 »
I got ****ed out of a 1st place award for a presentation of my research because not enough judges showed up.  I got highest marks on the entire rubric, and the only thing that differed with the other people who placed was the number of judges that heard them.  ****ing bull****.  I could use that money and CV fodder.
Offline HannahPeach
« Reply #15035 on: Wed, 24 February 2016, 17:34:37 »
What kind of research were you looking to present?
Offline BlueNalgene
« Reply #15036 on: Wed, 24 February 2016, 17:41:15 »
I'm a chemist PhD student.  I was presenting my work on Development of a Networked Sensor Array for Gas Microseepage Detection Near Injection Well Sites.
« Reply #15037 on: Wed, 24 February 2016, 17:42:00 »
No it isn't.
amiright demik?
I got no upper-body musclez.
« Reply #15038 on: Wed, 24 February 2016, 17:43:06 »
No it isn't.
amiright demik?
Tu sabes vato.
« Reply #15039 on: Wed, 24 February 2016, 17:43:45 »
****ing what
Heh hard digging holes OuO that's the point!
  • Live long and prosper
« Reply #15040 on: Wed, 24 February 2016, 17:49:08 »
I just learned that a friend I am reasonably close to recently tried to commit suicide. Fortunately he failed in his attempt, but is still hospitalized.
tp thread is tp thread
Offline swimmingbird
  • keyset hoarder
« Reply #15041 on: Wed, 24 February 2016, 18:13:35 »
**** man that's awful
sorry to hear that
Offline HannahPeach
« Reply #15042 on: Wed, 24 February 2016, 18:30:38 »
Are you guys having a bright future regarding the job market in the US?
I'm currently working on the masters and I am thinking about quitting because the
job situation is horrendous.
« Reply #15043 on: Wed, 24 February 2016, 18:43:36 »
sorry to hear that
It seems like more and more people are trying it these days..
I got a buddy who's tried it too.. sigh..............
Offline BlueNalgene
« Reply #15044 on: Wed, 24 February 2016, 19:10:27 »
The job market is very election dependent sadly.  Some of our funding sources tried to refuse to pay because they thought it was a republican lock - meaning that our global warming related research would be the first to go.  I don't really pay attention to the job market though.  I'm more concerned about research and going into academia.  I've done industry before and it wasn't for me.
« Reply #15045 on: Wed, 24 February 2016, 19:19:57 »
I am bothered about when the Arctic tundra lets out that gigantic belch of methane and all the rest of it accelerates in a big whoosh.
But it may take half of Oklahoma City being swallowed up in a sinkhole to get climate the deniers' attention.
- D Trump 2026-10-24
« Reply #15046 on: Wed, 24 February 2016, 20:20:46 »
I'm all kinds of ****ed up gh
Offline 27
  • The Maple Man
« Reply #15047 on: Wed, 24 February 2016, 20:21:58 »
You doing okay man?
IG: https://www.instagram.com/27mechs/                                        Website: http://www.mech27.com/
« Reply #15048 on: Wed, 24 February 2016, 20:22:00 »
This **** ducking works guys
« Reply #15049 on: Wed, 24 February 2016, 20:23:59 »
Oh **** wrong thread, this morphine ****ing works guys sorry
